brake light switch
vicboddy
- Given Name: vic
brake light switch
A while back now I bought a job lot of wooden boxes full of unknown car bits from a long closed garage. The other day I started emptying some of the boxes, and in one I have found some 50 brake light swithes as used on Jupiters (and I guess Javelins and maybe others). These are the switches which make the circuit to the brake lights when we depress the brake pedal. Should anybody need one of these simple switches -- I guess they are available elsewhere anyway -- I will be happy to let you have one.
For the sake of the story, I bought the lot because I wanted the wooden boxes, which were ex German army 1st ww ammunition boxes. The first two boxes I have recently opened were packed full of points for distributers, the next with generator brushes and the next.....with some live ammunition!
RGDS
Alastair Gregg
D7 CB 6079 CVG 166
Ecky Thump from Down Under
I was sleeping over that little lot.
Recommend a slow careful removal from the area in which your Jowetts are stored. What are you going to do then!!!!
Compliments of the Season,
Alastair Gregg
Alastair Gregg
Brake light switches
Vic: -
I would very much like one of these switches for the 'repair' of my 1930 Long Four.
It did not have brake lights when new - nor when I acquired it from a chicken run in 1966 - and although I am in the process of making as pair of 'vintage' looking stop/tail lights, I still do not have a suitable switch.
Please send private e-mail re: - Price £ or Euros, P&P etc.
vicboddy
- Given Name: vic
msuemason
Brake lights
Bonsoir, Vic et pourquoi vous n'avez envoient une e-mail?! Zut alors, j' voudrais essayer francais ...il faut que j'essayer ......as you can see!
Brake light switches? Maybe save couple for David? I know he had some difficulties with brakes on the Jupiter. I will direct him towards this message toute suite.
Sue Mason (Bideford 2009)
vicboddy
- Given Name: vic
Vic: -
Many thanks for that! I am already pressing the grapes!
Will you be at Wakefield?
Very best wishes, Ian H
DavidMason
- Your interest in the forum: Javelin, Jupiter, Bradford, Jowett 8, MGBGT
Light switches
Hi Vic
Yes can I take you up on your offer to Sue - I would appreciate one for my jupiter. I assume they are the 'manual'type. My jupiter has been fitted with a pressure switch on the hydraulic pipe and it seems to be faulty - everyone suggests I revert to the original type!
Address is:
David Mason
177 Chester Road
Macclesfield
SK11 8QA
I can pay by transfer or settle up with you in Wakefield -I assume you will be there
cheers
Address is:
David Mason
177 Chester Road
Macclesfield
SK11 8QA
cheers
JCC member
Vic: -
Delighted to report that TWO switches arrived safe and well during my absence last week.
Might this be an error? I notice that you had indicated you would send two to Sue Mason so is one of these misdirected?
I would be pleased to forward if required - or do I have a 'spare'?
Again many thanks, the wine is now bottled.
Regards, Ian H
Regards, Ian H
msuemason
brake lights
Well, not knowing anything at all about brake lights, but assuming that as there are two brake lights then then two switches might be required, I may have confused thing here when I asked for a couple. Maybe only one is needed afterall.
So.....
if there is only a need for one switch per pair of brake light, then I could take up the offer of the spare currently in the UK
Address as per David's posting.
Otherwise, Vic status quo.
(Maybe wives should keep out of this technical stuff and keep to the blogging)
www.jowett.wordpress.com
So.....
Alastair Gregg
D7 CB 6079 CVG 166
Numbers of Brake light switches
A logical assumption Sue but as you can now guess there is only one switch required in a Javelin or Jupiter and I suspect any pre war. But please don't stop posting, there is a lack of ladies here and another perspective on things is usually a good thing. Blogging www.jowett.wordpress.com is also a good thing
Alastair Gregg
Alastair Gregg
Sue; -
Yes there is only one switch for both stop lights.
In my Javelin it was screwed to the underside of the floor near the brake master cylinder and connected to it by a coil spring.
If you have not received one (or two?) from Vic, I will be pleased to forward the 'spare' he apparently sent me (I assume - without looking - that your address is in the members list).
vicboddy
- Given Name: vic
brake light switch
Hello Mike, a pair of switches on their way to you too. 2 so you have a spare, or can pass one onto a needy person. And indeed, see you in Wakefield, good, another glass of wine free!
Hello Ian, Two because they are a different size, and I did not know which would suit your car best. I suggest you keep the spare unless you find somebody in need (not Sue/Mike).
All best vic
All best vic
DavidMason
Hi Vic - 2 switches just arrived - many thanks - I'll only fit one!!
cheers - Mike (alias David)
I went to the dentist yesterday and, sitting in the waiting room, spoke to another patient who turned out to be another David Mason. We tossed a coin to decide who had the one available appointment we had both been called for!!
JCC member
