brake light switch
vicboddy
Your interest in the forum: Information. I have spares which have helped club members in the past. Obtaining info on equivalent parts, eg where to find shock absorbers for a Jupiter
Given Name: vic
brake light switch
Post by vicboddy »
A while back now I bought a job lot of wooden boxes full of unknown car bits from a long closed garage. The other day I started emptying some of the boxes, and in one I have found some 50 brake light swithes as used on Jupiters (and I guess Javelins and maybe others). These are the switches which make the circuit to the brake lights when we depress the brake pedal. Should anybody need one of these simple switches -- I guess they are available elsewhere anyway -- I will be happy to let you have one.
For the sake of the story, I bought the lot because I wanted the wooden boxes, which were ex German army 1st ww ammunition boxes. The first two boxes I have recently opened were packed full of points for distributers, the next with generator brushes and the next.....with some live ammunition!
RGDS
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Given Name: Alastair
Ecky Thump from Down Under
Post by Alastair Gregg »
I was sleeping over that little lot.
Recommend a slow careful removal from the area in which your Jowetts are stored. What are you going to do then!!!!
Compliments of the Season,
Alastair Gregg
Brake light switches
Vic: -
I would very much like one of these switches for the 'repair' of my 1930 Long Four.
It did not have brake lights when new - nor when I acquired it from a chicken run in 1966 - and although I am in the process of making as pair of 'vintage' looking stop/tail lights, I still do not have a suitable switch.
Please send private e-mail re: - Price £ or Euros, P&P etc.
vicboddy
Given Name: vic
Post by vicboddy »
Hello Ian,
I dont seem to be able to find your email address in the 'book' but no issue. I will post you a couple of switches today, they are free of charge and you can buy me a glass of wine one day to cover the postage. Regards vic
RGDS
msuemason
Brake lights
Post by msuemason »
Bonsoir, Vic et pourquoi vous n'avez envoient une e-mail?! Zut alors, j' voudrais essayer francais ...il faut que j'essayer ......as you can see!
Brake light switches? Maybe save couple for David? I know he had some difficulties with brakes on the Jupiter. I will direct him towards this message toute suite.
Sue Mason (Bideford 2009)
vicboddy
Given Name: vic
Post by vicboddy »
Hello Sue, A couple of switches duly put to one side. Let me know if wanted in due course and I can post them. A bientôt! Vic
RGDS
Vic: -
Many thanks for that! I am already pressing the grapes!
Will you be at Wakefield?
Very best wishes, Ian H
DavidMason
Your interest in the forum: Javelin, Jupiter, Bradford, Jowett 8, MGBGT
Light switches
Post by DavidMason »
Hi Vic
Yes can I take you up on your offer to Sue - I would appreciate one for my jupiter. I assume they are the 'manual'type. My jupiter has been fitted with a pressure switch on the hydraulic pipe and it seems to be faulty - everyone suggests I revert to the original type!
Address is:
David Mason
177 Chester Road
Macclesfield
SK11 8QA
I can pay by transfer or settle up with you in Wakefield -I assume you will be there
cheers
JCC member
Vic: -
Delighted to report that TWO switches arrived safe and well during my absence last week.
Might this be an error? I notice that you had indicated you would send two to Sue Mason so is one of these misdirected?
I would be pleased to forward if required - or do I have a 'spare'?
Again many thanks, the wine is now bottled.
Regards, Ian H
msuemason
brake lights
Post by msuemason »
Well, not knowing anything at all about brake lights, but assuming that as there are two brake lights then then two switches might be required, I may have confused thing here when I asked for a couple. Maybe only one is needed afterall.
So.....
if there is only a need for one switch per pair of brake light, then I could take up the offer of the spare currently in the UK
Address as per David's posting.
Otherwise, Vic status quo.
(Maybe wives should keep out of this technical stuff and keep to the blogging)
www.jowett.wordpress.com
Alastair Gregg
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Numbers of Brake light switches
A logical assumption Sue but as you can now guess there is only one switch required in a Javelin or Jupiter and I suspect any pre war. But please don't stop posting, there is a lack of ladies here and another perspective on things is usually a good thing. Blogging www.jowett.wordpress.com is also a good thing
Alastair Gregg
Sue; -
Yes there is only one switch for both stop lights.
In my Javelin it was screwed to the underside of the floor near the brake master cylinder and connected to it by a coil spring.
If you have not received one (or two?) from Vic, I will be pleased to forward the 'spare' he apparently sent me (I assume - without looking - that your address is in the members list).
vicboddy
Given Name: vic
brake light switch
Post by vicboddy »
Hello Mike, a pair of switches on their way to you too. 2 so you have a spare, or can pass one onto a needy person. And indeed, see you in Wakefield, good, another glass of wine free!
Hello Ian, Two because they are a different size, and I did not know which would suit your car best. I suggest you keep the spare unless you find somebody in need (not Sue/Mike).
All best vic
Vic: -
One spare for any deserving cause.
Wine maturing nicely.
See you at Wakefield
DavidMason
Hi Vic - 2 switches just arrived - many thanks - I'll only fit one!!
cheers - Mike (alias David)
I went to the dentist yesterday and, sitting in the waiting room, spoke to another patient who turned out to be another David Mason. We tossed a coin to decide who had the one available appointment we had both been called for!!
JCC member
