Wiring Loom
Wiring Loom
Can anyone help with the routing of the wiring loom on a Utility,I have sorted most of it,the problem I have is the routing to the semaphores,I feel it should run down the right hand side to the B pillar where one section goes up to the lamp the other across the floor to the opposite pillar and lamp .If I do this the wiring colours are incorrect and it appears too short to route any other way ,any advice please.
Nigel Jarrett
