Britool Hub Extractor- ebay
paul wilks
A Britool Hub extractor for a Javelin is advertised on ebay at £9.99. The Britool number is 956 the thread is 1⅝â€
This was posted earlier in the year by David Morris (edited): -
Hi there,
In a previous thread, Ian Howell mentioned that he had made up a tool for removing the later ( full hydraulic ) rear brake drums based on a standard BSP pipe coupler and blanking plug.
Ian thought that this was based on a 2" BSP coupler, but having been down to our local engineering shop, I can vouch that you would need a nominal 1.5" BSP pipe coupler. This ends up as 1.875" i/d and the one I found in stock screws nicely onto the threads provided by Jowett's on the centre of the rear hubs, just behind the securing nut.
It should be fairly easy to remove the hubs by either using a suitable blanking plug screwed into the outer end of the coupler as Ian mentions, or make up a tool by welding a plate across the open outer end of the coupler and fit a large nut and set screw set into the centre, with the nut welded onto the plate.
HOPE THIS HELPS!
Hi there,
HOPE THIS HELPS!
