I have tried to post replies using my registered name, but the message comes back with 'Sorry, this name is alteady teken' Of course it is, it's mine!
The only solution then seems to be to use 'Guest', which is a bit of a problem, but might explain why so many 'guests' appear in the listings.
Help please! What am I doing wrong?
Posting a reply
Logging on
David, I had exactly this problem. It's our fault! (or at least it was my fault).
You have to LOG ON before typing in your message. Otherwise when the system tries to log you on as a new member, you are already there! (of course you are).
Hope this helps.
Ian Howell
Hope this helps.
Ian Howell
JowettTalk Forum
Keith: -
Not a problem or a complaint, just a comment: -
I notice that when I visit a posting the little bell?! changes to white - usually. I know the reasons for this, BUT . .
Today the one against Javelin did not change even after 3 or more visits.
Just passing through.
Posting a reply
Hi there,
I believe I've got the hang of it now!
Although I seem to need to actually log on at least twice, before the 'Log out [David Morris]?' message comes up. Am I still doing something wrong?
