Engine: 7hp, 1932
Engine: 7hp, 1932
Photos of engine strip down and rebuild
Jowett twin 7hp engine strip down and (hopefully) rebuild with new parts as needed. Mostly complete at the start, but with some modifications to dynamo (reapairable?) and missing distributor and coil.
g_id=34947,_ /PersonalAlbums/Julian/Jowett,_ julian,_
From the JowettTalk webmaster.
Front View
Rear View
Summary
Full engine viewed from rear.
g_id=34955,_ /PersonalAlbums/Julian/Jowett/IMG_6030.JPG,_ julian,_
Carburetor
Close-up of carburetor type 30VEH
g_id=34958,_ /PersonalAlbums/Julian/Jowett/IMG_6034.JPG,_ julian,_
Fuel Pump
Dynamo
Close-up of dynamo, type C418A AJ3. Note "modification" to distributor drive housing!
g_id=34964,_ /PersonalAlbums/Julian/Jowett/IMG_6037.JPG,_ julian,_
Timing chain
Close-up of crank(20t), cam(40t) and dynamo(16t) gears and timing chain.
g_id=34967,_ /PersonalAlbums/Julian/Jowett/IMG_6038.JPG,_ julian,_
Breather
Breather vanes, some missing/damaged
g_id=34970,_ /PersonalAlbums/Julian/Jowett/IMG_6044.JPG,_ julian,_
Left cyclinder
Right cylinder
Piston - 30 thous o/s
Piston top showing 30 thou o/s markings.
g_id=35117,_ /PersonalAlbums/Julian/Jowett/IMG_6052.JPG,_ julian,_
White Metal Pieces
Pieces of white metal found in sump plug.
g_id=35120,_ /PersonalAlbums/Julian/Jowett/IMG_6069.JPG,_ julian,_
Cleaned Heads & Valves
Cylinder heads and valves after clean-up. Valves still to re-grind.
g_id=35123,_ /PersonalAlbums/Julian/Jowett/IMG_6070.JPG,_ julian,_
Clutch Assembly Removal 1
Cleaned up clutch assembly ready to remove.
g_id=35126,_ /PersonalAlbums/Julian/Jowett/IMG_6071.JPG,_ julian,_
Clutch Assembly Removal 2
Screws removed (3 re-fitted loosley to retain plate as springs push plate outwards before prising off).
g_id=35129,_ /PersonalAlbums/Julian/Jowett/IMG_6074.JPG,_ julian,_
