I'd be glad of any advice, or diretion to any literature.
SA seat removal and replacement
114
- Given Name: Roger
Re: SA sear removal and replacement
I'm assuming the typo should be seat. The easiest way is to remove the seat hinges from both the back and bottom and remove the seat back. Push the lever under the seat to release the catch and slide the seat forward until it clears the tracks. Then lift the seat out of the car.
There are three sliders mounted on wedges. They are held by screws that pass through the floor and held by nuts under the car. Not very complicated.
Cheers
Cheers
114
- Given Name: Roger
Re: SA seat removal and replacement
Thanks Scott. Typo sorted also
