The passengers side door lock on my 8hp, doesn't lock when you flip the inside door handle to locking position.
Any one have pictures of what the inside of a complete working one should look like?
Have a idea what the issue could be?
I have yet to pull it out to look at it.
Passengers side door lock on 8hp
The Bradford man
- Given Name: James
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
Re: Passengers side door lock on 8hp
Hello James.
I only have photos of the early 30s 7hp Long saloon door mechanisms, and I don't know if they are of any use, but here they are.
This is a rear door mechanism, which I think allows locking by use of the interior lever.
Bottom right is a near-side front door mechanism which had the key to unlock it using the outside handle. You had to open the near-side door and lean across to unlock the off-side door with the interior handle. The other three are rear-door mechanisms.
Tony
Tony
