Jowett Javelin PB Engine Repair
From Mike Allfey
I have just received the devastating news that Phil Squire’s, twice re-built by me, Javelin PB engine is currently shifting coolant into the engine oil sump at an alarming rate. This rate is best described as 3 litres on a run of a handful of kilometres (i.e. from Belgrave to Belgrave South and return). My own suspicion is that the crankcase has cracked somewhere.
Below is what I have asked Phil to do, initially.
Quote:
IMPORTANT!
Do not start the engine.
1.     Remove the radiator cap and check the coolant level.
2.     If it is low, the coolant will have sunk to the bottom of the sump, and that is what the oil pump will suck in first. Not at all good for the crankshaft bearings!
3.     Remove the four sparking plugs.
4.     As I suggested, use a small diameter wooden dowel as a dipstick at each cylinder to find out if coolant has filled a cylinder.
5.     Still, with the plugs removed, and the plug leads well away from an earth point near the plug holes, crank the engine with the starter motor and see if any coolant is expelled from one or more cylinders. If so let me know.
6.     Remove the rocker covers and look for coolant there. If a cylinder head gasket has failed, there would be a margarine residue inside the rocker cover. If none is evident, top up the radiator and observe the push rod bores/tubes in the cylinder heads. Coolant that has collected in a tappet chest, will drain at those points. With the rocker covers in place, it would continue to drain through ports into the sump.
7.     Last, drain the sump, remove the sump and look for coolant coming through from underneath.
As I mentioned, I consider that the coolant consumption is far greater than for a cylinder head gasket leak point.
End quote.
Is there anything further I could suggest? That is why I have copied in British and New Zealand enthusiasts, in case I have missed something.
Now, it gets serious.
I want to know exactly what went on with this engine, that was supposedly reconditioned by a “Jowett Expert”. I demand the truth on this, because I have contributed too much of my life building this luckless engine, two times from scratch. The crankcase had been extensively weld repaired prior to Phil’s purchase of the PB Javelin. I am fully aware of the term caveat emptor (buyer beware), however, there were far too many signs of the engine having been botched by the so-called “Jowett expert” that it beggars belief.
To provide a smidgeon of local history, my first involvement in this disaster was at a garage day held in my workshop. The dismantled engine (as a result of a broken connecting rod) was shown to me. It is understood that I suggested to Phil that the damaged parts be taken to a local engine specialist for repair and machining.
The absolutely bizarre point is this, I would have seen the previous welding and would have recommended finding another crankcase set and start from there. I would have rejected such a weld repaired crankcase out of hand.
Since I started this message, Phil has carried out Step 4. Coolant in cylinders two and four. I can’t really believe that the cylinder head gasket has failed. It could well be a crack in the cylinder head. But, to consume 3 litres of coolant in so few kilometres? And have the oil sump fill over night?  I am really wondering?
Any comment will be gratefully accepted.
Thank you,
Response from Neil Moore,
Mmmmmmmm, Mike , sounds like a gasket if water is in both heads on one side. It's possible for water to migrate up the inlet ports on one side to the other cylinder as gravity will push past slightly open valves. There are a couple of checks for gasket leaks or block leaks without removing the head but sounds like that's inevitable.
     A compression test (after draining the water contaminated oil so it doesnt get all thro the oil ways and draining the filter into sump).  Will show a gasket leak .    Enough oil remains to crank  engine over safely.
     A dummy plug with air fitting can with low air pressure show leaks cyl to rad or cyl to sump .   And removing pushrods covers will show a crack in the valleys with  water oozing tho  that wouldn't get water in cylinders!
      Other long shot possibilities are a porous liner or a pinhole in same.
      A head crack but I've never had one to leak water into cylinder !
     Actually the easiest way to find a crook gasket is to drain oil and water , put plugs back and turn the engine over on crank handle watching with the dizzy cap off to indicate the cylinder. You'll feel the lack of compression easily!
       Have fun.     Neil Moore
Response from Drummond Black
Mike,   I tend to agree with Neil.     I have an engine in the workshop at present which suffered from a similar issue.  It was showing signs of leaking on all cylinders.  ???
The timing cover and the rear water inlet tubes ( including both bottom hoses) were removed.  For the rear area, Blank flanges were made up, and with a gasket, This blanked off both cylinder banks.
At the Timing Cover front face of the crankcase a flange, that would cover the water outlet area, was made for each side.  An adaption for a tyre valve was soldered to it to allow each cylinder bank in turn to be pressurised in turn.    The bank containing cylinders 1 and 3 held a pressure of 4 PSI with no issue.    The bank containing cylinders 2 and 4 leaked badly.    This was traced to the Cylinder Head Gasket
area along the top.   On removing the Cylinder Head the Gasket was found to have totally collapsed.  The was found to be an Auckland Gasket.    This is the first one I have ever found, if fitted correctly, to have been in a bad state.
So, similar check to Neil located the issue.   I must say that the liner protrusion on that side was really not sufficient.  This is still awaiting rectification.
Trust this assists.
Further from Mike.
Dear All of You,
I tend to agree with you Neil and Drummond. However, after such careful work with the cylinder head studs and cylinder liner protrusion, along with warming the engine and leaving it to stabilise for twenty minutes, and with my torque wrench at the same setting as the first finish-tightening, all of the studs tightened (solidly) exactly the same amount. That meant that I was quite confident. With solid copper liner seat spacers and shims, I opted for 0.008” liner protrusion. Also, the cylinder head gasket supports were shimmed to the same protrusion with brass shims I had made. I was very wary of any more protrusion due to the balance pipe flanges having been machined off flat with the gasket surfaces. The machining of the flanges is something I have never condoned, but the engine reconditioner’s shop told me that, with all the welding, the gasket face was ‘all over the place’, a reasonable explanation and with the current gaskets performing well, I felt they would manage easily with the flat surface.
Having experienced a similar problem with Richard Homersham’s engine, which did reveal a ‘sunk’ cylinder liner (just how with copper spacer and shims, I still don’t know why), I thought such problems were sort of beaten. In that instance, a 0.003” shim was added to the one liner. Now, I am wondering. Could bored out liners ‘give’, Ferguson tractor liners did after just a 0.010” oversize boring operation. The other thing that concerns me, are all of the four cylinder liners in this engine from the same batch? Another thought worth pondering is the age of the metal that makes up the crankcase set.
With the massive coolant leakage at the head gasket, and with such a short distance travelled, since the leakage discovery, shouldn’t there have been a significant cloud of steam at the exhaust and, wouldn’t there have been the distinctive smell of hot coolant inhibitor (anti-freeze)?
I suppose I am the only Jupiter and Javelin owner who has never experienced a cylinder head gasket failure in 54 years! That means that I do not know what the exhaust would have been up to on that short run.
More from Neil.
Hi Mike and all,    Our modern Auckland gaskets are not perfect, as the copper if not supported will fret and fracture , so liner heights are important.   As we all know setting them is a not so precise exercise as the block /gasket surfaces are after 60 odd years variable. However saying that  we are only trying to seal 4psi water around the edges but the liners must have the 6-8 thou above the edges. I always bottom the liners without shims and average out the readings around the liner at say 4to 6 spots.    Some blocks the liners will be different on same side.     The other thing to watch is bore size as standard bore gaskets are no good on bores 75mm or bigger. We have o/s gaskets fit bigger bores as the gasket fold will be in the bore and not seal.     Have fun.     Neil
   Note the shims must be measured individually as they're not always flat new and then added together to get heights,.   Use a micrometer, a vernier is not accurate enough.
Response from Jim Scott
Hi Mike and all,
I can't imagine Phil's and your disappointment, I know it has been a long road for you.
I haven't had much experience with the Jowett engine, yet!! and I know you are all going to threaten me with all sorts of terrible things for my suggestion, but I have had some experience with Peugeot engines which are also wet sleeve. I had all sorts of grief with two seperate 2lt engines.
It was suggested to me that I give the first one a dose of Chemiweld. I was loath to try it at first, but in desperation I did give it a go and and believe it or not it worked and it kept on working for years, until the car was sold. I am a believer, to the point I carry a bottle with me when I travel, now days. The main thing is that you get the engine almost to boiling point before adding it to the radiator.
I know it is probably not a purists fix, but it is worth a try for about $15 a bottle.
I know it doesn't give you the answers you want, but it may save a heap of frustration.
Please don't drum me out of the club for this suggestion, but I have little else to offer.
Good luck.
Cheers, Jim Scott
From Keith Clements
Check torque of cylinder head nuts on 2.4 head. If they move likely block cracked or threads stripped and gasket seal broken.
I now support the head gasket around the centre stud as I did get a few gaskets separate. But they were the original type.
When head removed take picture of each side of gasket before cleaning to check where pinch was loose.
Response back from Mike.
Many Thanks Keith,
Good point about checking the torque on the cylinder head at cylinders 2 and 4. It was that side that caused all the grief that generated my Technical Note about fitting the extended stud through the coolant inlet port.
I do tend to doubt that the threads in the crankcase have stripped, and the Number 7 stud (in the torque sequence) was threaded into new metal, albeit welded metal.
Also an interesting comment about gasket separation, also from Neil Moore. I have always used the Series III cast aluminium support, shimmed to the same height as the liners on that side. These can differ. I never did like the tube and plate version.
This separation in the gaskets makes me wonder if the Jupiter’s copper-asbestos-steel wasn’t the result of similar concerns? I have been impressed with the NZ gaskets though. I think I have a new genuine Jupiter gasket here somewhere. Probably illegal in these PC times!
I cannot get to the task for a couple of days, but will let you all know the result of the ‘Torquing Test’. One thought has occurred to me – the Number 4 stud is, if I remember correctly, the one that was 0.5625” (14.3 mm) longer than the one for the other side. If that stud has ‘given’ then the gasket would have lost its clamping force at the liners.
We shall see!
Now from Andrew Henshall
Dear Mike & Phil,
You both must be so disappointed and feeling very frustrated at the same time. You have put in major commitment (time & money) & the results of many years of your experience Mike into this engine, and so this news is very unexpected.
I have little to add to the feedback from the others, except to say that with a reported loss of 3 litres of coolant in a drive of only 6 km, and with coolant now present in two cylinders on one bank, the engine must be running fairly roughly with a fair amount of steam coming out the exhaust at idle! My experience when running various engines in this condition is that they continue to produce sufficient power to drive around on the road, but they really don't like to idle, and they will not restart after cooling down due to hydraulic lock.
Why not analyse the most likely single cause of coolant being present in two cylinders on one bank, as well as coolant collecting in the sump, because these symptoms are usually due to quite separate causes? Failure of the head gasket at the No 4 head stud, (it being on the centre-line), can result in coolant in both cylinders on that bank, but how does so much coolant get into the sump. Surely not past the rings! I wonder if the crankcase has failed at the bottom of the No 4 head stud causing a direct path for coolant into the sump, and simultaneously failure of the liner seals at the head gasket on both cylinders?
Note: Wal Munro's Javelin engine failed with steam & coolant pushed out the radiator cap during a drive, and massive quantities of coolant in the sump, yet it started & ran quite well. In October 2013, after a few years of sitting in Wal's garage without coolant in the engine, I measured the compression pressures and they were OK at 110 - 130 psi. The engine started perfectly and idled beautifully at about 400 rpm! The subsequent strip down in the UK confirmed a failed head gasket.
When a liner seal at the head gasket fails, it invariably pressurises the coolant system with combustion gases, and the result is always that coolant & steam is expelled from the radiator cap when loading the engine during a drive. There is no mention of this in your report below however.
As far as the previous history of Phil's engine goes, he purchased the car from Adam Francis in VIC, who purchased it from Barry Allertz in NSW, who bought it from John Ireland in Brisbane QLD. I've been told that John did a nice job in restoring the body and interior, but he was hindered by some very strange mechanical ideas. He would only let you help when he wanted a hand with something, and would not take advice on anything.
I wish you all the best and look forward to gaining a better understanding of the issue at your Workshop Session on October.
Response from Mike
Thanks Andrew,
My thoughts entirely. However, with the dramatic gravitation of coolant to cylinders and sump, I have asked Phil to not start the engine at all until I get there, maybe on Wednesday due to a two day commitment.
I do have serious doubts about Number 4 stud on that side. My initial plan at present is this:
Have the car on the hoist.
Remove rocker covers.
Fill radiator with coolant mix.
Observe if there is leakage to sump via push rod tunnels. If so, crankcase half could well be cracked.
Check torque of cylinder head bolts. This could be revealing.
Maybe drop the sump and watch for what is coming through cylinder bores and elsewhere, also revealing. The ring gaps were inside tolerance, and I find it hard to believe so much coolant can get through there in such a short time span.
Work out what to do next.
What really baffles me is the apparent lack of steam at the exhaust. In Belgrave traffic the engine would have been idling for a fair time. At home, there would have been radiator overflow puddles. Also, there would be a lingering smell of coolant that has been through combustion cycles. That would be noticeable, just a drip onto a hot exhaust manifold gets Sue’s concerned attention.
As mentioned before, we shall see,
Andrew...
Jim!!!! How Could You???? Please go and wash your mouth out (preferably with Chemiweld)!
Seriously, Chemiweld does indeed work in some situations. My concern, and probably yours was too, is what does Chemiweld do to the cooling system performance, as all the surfaces in the block & radiator will be coated with gunk. Chemiweld (in my opinion) is probably the best sealant available but I would only use it as a last resort or in an emergency, because it's so hard to get out of the block and the radiator at a later stage.
Back at Ford Motor Co of Australia, when we had the well-known issue of head gasket failures on our 6-cylinder engines (pre BA Falcon), people tried everything to keep their cars going, and the most common backyard solution was Chemiweld. Katrina & I actually ran a 6-cyl EB Falcon tow-car for years, and, as expected, when it got to 150,000 km the head gasket failed. We replaced the head & kept running the car. At about 250,000 km, the head gasket failed again (as expected), and this time I used Chemiweld to get it running again, and not too long afterwards traded the car in on a 6-cyl BA Falcon with the new multi-layer steel head gasket! Our 2003 BA Falcon tow-car has now done >250,000 without any head gasket issues, and in fact the field experience with BA - BF 6-cylinder engines is that head gasket issues are very very rare. I was the BA engine program co-ordinator at Ford Product Development, and actually stood in for the design engineer responsible for the head gasket, pistons, rods, crank, bearings, etc after he had major heart surgery. I can't take any credit for solving the head gasket failure issue though!
The bottom line with Chemiweld is that it only works in some situations. It doesn't usually work for radiator leaks, and if a head gasket failure at the cylinder top seal has been run for any significant length of time, then the gasket will usually be blown out completely by the combustion gases and there is no way that Chemiweld can seal it again!
Yes, Phil must definitely not try to start the engine with the risk of hydraulic lock present!
A long time ago, I had a head gasket fail on an in-line engine, which resulted in a cylinder part-filling with coolant overnight. I knew this was the case because it would not crank over by hand. I removed the spark plugs, and rather than continuing to hand crank the engine, and being young & stupid, I gave it a decent go on the starter motor to clear all the coolant. The jet of high velocity coolant that came out the spark plug hole was very impressive! I actually got the engine running again, but quickly decided that it needed to be pulled out of the car and rebuilt.
Cheers,
Andrew
More from Neil.
Hi Mike and all, another thought,   Which mention of extensive welding brought to mind.   This is very unusual but  it did happen once. Some blocks corrode badly on lower central part of the water jacket between liners  with a deep vee' hollow. It's not always obvious and usually occurs outside the sump studs and water goes onto the ground. However this one block was further in and leaked water inside the sump studs and straight into the sump. With sump off and water into engine it was soon obvious and really the only way to fix is loctite metal mend stuff, as it's impossible to weld in there.
    However that's not your problem, I'll bet it's a gasket gone. The question is why so soon?   Probably liner heights. Best to remove gasket carefully if possible and measure the compression difference between the liner squash and the block squash to see if liner heights ok.      Again with a micrometer.
    Our gaskets after the asbestos nonsense made us change materials did nobody any favours.  It's now a cellulose material, 10 thou thicker , but softer and must be retightened hot . It's definitely not as good as theoriginal  German made Reintz material we used but that's no longer available .  I have investigated another material but it would've doubled the cost so really wasn't a starter and with reasonable fitting  the current material gives quite good results   Up to 9::1  compressions          Regards Neil
and Keith
I would not bother putting more coolant in. If you do just use water.
A compression test will immediately tell you if the the gasket is gone ( although it could also be a symptom of head crack , valve gone or liner crack). Using compressed air via the spark plug is also a way to see where the decompression is going.---bubbles in coolant , noise in carb or exhaust port or noise in oil filler.
My money is on a cracked block.
The Coolant Leakage Saga
Back to Mike again after some investigation.
Hello Jowett Enthusiasts,
This morning, after some illness, and with doctor’s permission I managed, at last, to have a look at Phil’s Javelin engine.
The first action was to remove the valve rocker gear in order to check the torque at the cylinder head nuts on the head for numbers 2 and 4 cylinders. My torque wrench was set to 36 lb. ft. (as when the engine was assembled) and all studs were found to be resolutely firm at that setting. I must confess to having expected the nut/stud at position ‘4’ in the tightening sequence, to have shown signs of weakness, but it held firm.
Next, it was noted that there was no coolant leakage around the periphery of the crankcase face – another satisfying aspect after all the welding repair work in that area. Also nut/stud number ‘7’ (extended through the coolant inlet) was satisfyingly firm as well. There was an evidence trace of ‘mayonnaise’ coming from No. 4 cylinder’s exhaust pushrod bore. I tend to put that down to the engine’s attitude in the body frame. In addition, there was absolutely no coolant migration through the cylinder head nuts.
I then increased the torque value to 38 lb. ft. and progressed through the sequence. All nuts did tighten, and all by exactly the same amount, by eye check, not angular torque wrench measurement. Again, very satisfying.
My torque wrench is of SDI manufacture, related to Snap-on hand tools and was made in USA. I believe it is reasonably accurate, well we get the feel for these things don’t we?
Over the years, since using solid copper liner spacers c/w shims, and using the New Zealand head gaskets, I have used the 36 lb. ft. setting with success, including on my own Javelin and my Jupiter – along with half a dozen other engines.
Phil has been provided with other checks that I will be involved with, which means that we shall see what develops. I will keep us up to date with findings.
My thanks for your input, and Jim, I have no real concerns with using a chemical sealer (BarsLeaks or ChemiWeld), so, please do not worry about your suggestion. It was valid.
Mike A.
Response from Keith
Getting there.
Have the heads valve seat inserts?
What is compression on each cylinder?
Empty coolant by taking head drain plug out. Turn engine by hand whilst listening for air escape with tube stuck up drain plug hole.
You would be able to do a similar test with a compressed air adaptor in a spark plug hole.
The water to oil transfer may be caused by gasket failure around oil return holes in head. By somehow blocking tappet cover breathers and feeding compressed air into crankcase breather pipe you might be able to detect leak.
A compressed air adaptor on the water filler could show leaks by listening down each spark plug hole and down each oil return gallery * with rocker cover off.
Hi Keith,
I think I forgot to mention previously that I had asked Phil to use wooden dipsticks at each plug hole at Nos. 2 and 4 cylinders. Yes, coolant present, and more in 4 than in 2. With engine cold and standing, the radiator level has remained static.
The heads have valve seat inserts, now that you ask, there’s a good point to follow up. There is always a first time.
We are going to try listening for gasps through the drain ports. My deafness will require that Phil will do the listening. The same with compressed air through the plug holes. I will also carry out a compression check, both cranking and with crank handle to get feel. Rather cramped in the garage though!
We have a Jowett jaunt in South Australia next week, so progress on this will be delayed a bit.
All the best and thanks for the input,
Mike A.
Circlip on gudgeon pin
On an early Pirelli Marathon one of the circlips broke. The rally car started to create a useful smokescreen and continued till the end of the 3500 mile rally.
On investigation at home, the circlip had almost worn its way through the liner. Now that would have been interesting. A steam powered Jowett.
Other competitors remarked they could smell the Jowett miles ahead.
All engines since then have been rebuilt with PTFE plugs for the pins.
Drummond Black
Given Name: Drummond
Re: Jowett Javelin PB Engine Repair
Post by Drummond Black »
Hey - You failed to report that the Engine got at least 3 tins of STP poured into the oil every morning !!!!!!!
That's what kept us going ....... That's maybe what the Italians were smelling ?????
DB
There has been lots of really good advice offered on this problem, well done folks! The only additional bit I can add is that here in Severnside we have developed a dry air pressure technique for blocks that is a good way to 'sniff' out cracks before going any further with a rebuild. There is nothing worse that finding the sump full of water just after a long ( and expensive) rebuild.
Our experience with lots of blocks, both previously welded and not, has shown that we only get around a 15% success rate, Sad, but true over about 20 blocks. Is there pattern? Not really, generally the very early blocks are better. Later ones seem to be weaker and more prone to corrosion. However, there might have been a very late batch that were better?
The best plan seems to be to find a very early set that visually seem good ( the lands around the head faces is a good place to start ), then to do an air pressure test and if this passes, then to start machining the block to bring it up to as near to Series 3 standard as possible. Obviously, you cannot introduce the extra webs found in a Series 3, but you can improve the oil way sizes and the pipework for the later oil pump. Repeat the air pressure test and if all seems good, then commence the rebuild, not forgetting to sleeve the rear seal face on the crankshaft and fit 'O' rings to the rear timing case cover. The crank, con rods and flywheel should be balanced as a set and the latest Series 3 oil pump fitted, having pre-set the pressure valve. One small point, but annoying if discovered, is that we have found problems with bell housings not being a good fit to the crankcase, around the rear oil seal area. Our spares shed has a pile of rejected bell housings that might just come in handy one day!
We had one engine where some idiot had machined the head faces so much, presumably to raise the compression ratio, that even the water transfer pipes wouldn't fit! Needless to say, this also caused water leaks internally in the heads and we had to scrap them.
I know this isn't much help with this engine on the thread, but it sounds as if it has been extensively welded, which is always a poor omen. We have found previously welded crank cases that pass the air pressure test, only to fail when checking the crankshaft rotation tests due to distortion during the welding process. Proceed with extra care when cases have been welded! There doesn't seem to be any particular spot where the crankcases fail due to cracking, it can be absolutely anywhere!
On a brighter note, I had one engine that I had built up carefully some years ago, only for it to crack along the roots of one cylinder bank when tightening up the heads on the bench, with a sickening and heart stopping noise! I had been closely following the instructions in the Jowett Handbook in those days, having not learnt to avoid the cylinder projections they advised in favour of the 0.006" now accepted as a maximum. I learnt the hard way! Anyway, in desperation, I took the complete engine down to a firm in Tiverton who specialised in aluminium welding and asked them to weld up the crack across the base of the bank of cylinders, accepting that technically my engine was now not exactly a 'flat four'. In a few minutes the job was done, after a bit of pre-heating. Back in the car, the engine ran perfectively for many thousands of miles! Later, the same firm welded a new base on our kitchen pressure cooker as we couldn't afford a new one, but that's another story!
Hope this helps?
One Photo Reveals Quite A Lot!
Dear Neil and Keith,
The attached photo shows the cylinder head from Phil Squire’s engine. The engine is out of the car and on my work bench and the following points have been noted:
1.     Cylinder liners’ protrusion outboard of the crankcase head gasket face is currently 0.004” to 0.006”, measurement taken with a bare cylinder head progressively tightened to 18 lb. ft. and checked with a set of feeler gauges around the periphery of the joint. Original assembly setting was 0.006” to 0.008” with cylinder liners on copper spacers and brass shims.
2.     I have had a look at the two liners and have not yet found any sign of cracking.
3.     The cylinder head gasket is still attached to the cylinder head surface, so no investigation on the far side yet.
4.     The cylinder liners had been bored to 0.020” over-size.
5.     The liners’ lip indentation into the gasket appears to be uniform. The indentation at the No. 2 cylinder, in the blackened area is consistent with the rest of the circumference.
6.     One point that intrigues me with this one. The engine was cranked with the starter motor, with sparking plugs removed to expel coolant from the two cylinders. Then it was topped up with coolant and, on checking the cylinders with a slim wooden dowel, there was already 12 mm of coolant in the cylinder. This was in the time it took to move from top-up position to the wood ‘dipstick’ position. Sounds alarming.
7.     My theory is that maybe the crankcase has yielded significantly and that one or both liners have been moving in both directions, depending on the stroke cycle. Has this ever been heard of before? I mention this because the cylinder head nuts had held their tightening torque. Many years ago, I had a VW Beetle and I could not understand why the tappet clearances kept opening up. Then I lay under the car while its engine was idling – to my horror, saw all four cylinders were oscillating! The head nuts were loose, but the car had kept going.
8.     An amazing aspect with this Javelin engine, especially with the small amount of use since the leakage commenced, the vast amount of ‘mayonnaise’ (posh Devonshire folk would probably call it ‘clotted cream’) residue inside the crankcase assembly. This is taking some cleaning out.
The rate of coolant flow into the cylinders, to me, seems an enormous flow rate for just a non-seating head gasket. I had visions of a lump missing from the top of the liner’s coolant contact area!
I am, probably, the only Jowett owner who has not had much experience at all with gasket failure, even on my Jupiter when it still used gasket material at the crankcase seats. I have seen the ‘mayonnaise’ condition numerous times on Standard 10s and more recently on Ford tractors, but that was the result of cavitation erosion.
Any heartening comments?
Mike A.
Last edited by Keith Clements on Thu Oct 26, 2017 9:05 am, edited 1 time in total.
I have at least 30 head gaskets showing similar issues. My long held view is that the block stretches and I have proved this by torqueing the head down to 20 lbs/ft with no head gasket, measuring gaps all around head and leaving for a week and then measuring again. It seems this block has stretched 4 thou or at least the liners have sunk 4 thou. I think this is enough to have caused the problem. I set to 8 thou protrusion after one week of stretching.
Different blocks stretch differently depending on corrosion, crack propagation and condition of metal due to fatigue. The annealing and malleability of the copper liner shims will also have an effect.
This all assumes you start off with a block and head that have been faced and the liners have been set and are seating properly.
The fact that each head bolt maintains its torque should be a good sign but could it be that the registered torque was incorrect? Worth comparing different torque wrenches. Or could it be that the nuts were not free to move due to bad thread or bad washers?
Is the muck at the bottom of cylinder two just drips from inside or has that gasket area failed there as well?
It could just be that it was a faulty head gasket which would be the most joyous explanation but it does look like the copper is intact. I did have more than one fail where the copper had broken at cylinder 'ring' and the filling had been pushed or burnt out. I now use the NZ gaskets and have not had any problem with them.
I suspect the retorqueing of the head after start up, warm up and after a 100 miles may not have caught the stretch and sinkage in time. Once blown the leak just grew.
The way forward should be to inspect by checking for cracks, check flatness of block and head and refit with a new gasket. Check compression on assembly and every few miles.
To Keith, Drummond, Andrew, David (Morris), Neil (NZ) and others who have responded - grateful thanks.
Having thought on this topic and sort of slept on it, I have decided to take the initial action in an attempt to help resolve the concern. I should make it clear that Jowetts only ever have concerns, never problems!
I will be cleaning, gently, the liner lips' indentations in the cylinder head gasket, carefully leaving it secure on the cylinder head face. Currently, the oil sump, anti splash plate, pistons c/w connecting rods, oil pump base and the liners are removed from the crankcase. The engine is bolted to the work bench, sitting on the flywheel housing vertically. This provides good access to the lower inside of the crankcase.
The liners and their spacers and shims will be cleaned and inserted into the crankcase. The cylinder head will be mounted on its studs and progressively tightened in small steps. From the 18 lb. ft. stage, the liner skirts will be checked for freedom of movement inwards and outwards in the crankcase. I get the impression that the liners (both or just one of them) will be free to either rotate or even oscillate between the crankcase seat and the head gasket face. Should this happen, it is further proof that the RHS crankcase has 'yielded' after it was tightened. This, of course, is assuming that the cylinder head gasket has not relaxed towards its original thickness. The liner lip indentations are still well pronounced, but difficult to precisely measure due to the copper and gasket material having 'swelled' towards the coolant gallery in the crankcase.
It should be pointed out that I now realise that the crankcase-half yielded at the first tightening of the cylinder head nuts during the engine's initial assembly in my workshop. This was revealed by the crack at the rear face happening over a day after the head was torqued. After the welding and the extension of Number 7 head stud through the coolant entry port, the cylinder head nuts tightened in a very satisfying manner. That proves to me that the crankcase has yielded again without cracking. There has not been any sign of coolant leakage at the periphery of the head gasket.
I will, of course, advise of progress, should there be any at this stage.
It must also be stated that I still have great faith in the New Zealand cylinder head gaskets, but I do believe that they do receive a fair amount of blame for coolant ingress to cylinders, when in fact crankcases had probably yielded. In addition to that, I still have great faith in the Javelin/Jupiter engine. It is sad that the Rover 75 is currently going through the same process of owner/mechanic ignorance (maintenance cost cutting too) that the Jowetts went through after production ceased. We never learn!
All the best and thanks,
Mike A.
I may have missed (probably have!) previous correspondence but DON'T FORGET to get the correct protrusion of the liners above the faces of the crankcase.
As I am sure you will know, this can be adjusted by means of shims on the 'shoulders' of the liners.
Grandma's and sucking eggs?
Thanks Ian,
The cylinder liner nip surfaces on the head gasket were cleaned and then the head was set in place with the securing nuts evenly tightened to 18 lb. ft., at that torque the liners feel very secure at their skirts where they protrude into the crankcase. The next step will be to repeat the same activity with a light smear of Engineer's Blue on the liner lip to see if there is a 'gap' in the ring at the head gasket surface.
Parts have been ordered and we shall see . . .
Mike A.
G'dday Folk,
An update while we are waiting for the spares to arrive. The liner lips for cylinders 2 and 4 were cleaned and a minimal smear of bearing blue applied. The cylinder head, with the gasket still adhered to its surface, was slid in place and gently torqued as normal. the liners were seated on the shim packs used in the engine's rebuild. The head was then drawn off using my head removal tool. Inspection showed that the liner lips had made no contact with the gasket in the areas shown in the photograph in an earlier report, i.e. above the exhaust valve, arcing towards the inlet valve t both cylinders. The head gasket was then removed very carefully. Not too easy with the current gasket type. Inspection revealed that coolant had been entering both cylinders from that side as well. The gasket residue was cleaned off and, using my Moore & Wright ruler as a straight edge, could not find any visible depression at the areas where the coolant leakage had occurred. Will check this more thoroughly after giving the head a thorough pressure wash.
The brass liner shims were measured and found to have maintained their original thickness. The two copper spacers, however, had settled from their original thickness, 0.029", to 0.0285". I would not think that would cause a flow into the cylinders, probably comparable to the Wannon Falls in Western Victoria - after a welcome good rain! In addition to that, the pinched cylinder circumference lip at the gasket appears to be consistent at 0.065". The head surface face of the gasket will be gently cleaned and measured again to confirm. All of these measurements have been taken with the one micrometer based on the theory that, he who has just one micrometer can vouch for the accuracy of measurement, but he who has two micrometers is never sure! Interestingly, my new Starrett digital Vernier agrees completely with my micrometer - so now I am double sure.
Having taken these measurements, I feel that the concern could be a combination of head gasket failure and, possibly, crankcase yield in local areas.
The 'clotted cream' has taken considerable cleaning out of the engine. Understandably, we are reluctant to completely dismantle the engine yet again. Fortunately, the cream is in the oil-affected areas of the engine. For example, the spot welded joint at the tappet chest covers, proved to be a fair challenge as did the oil surge baffles in the oil sump. I am a little bit concerned about any clotted cream residue that may be lingering in the oil galleries and crankshaft drilled oil-ways. The plan is to assemble the engine, fill with fresh oil, and, while on the bench and with the sparking plugs removed, crank the engine with the starter motor until oil pressure builds up. Once it has built up, we will check the condition of the oil exiting at the rocker shafts.
Does anyone know if it would be beneficial to pack the oil pump with petroleum jelly to assist with priming, in the case of a Jowett engine? The Service Manual for the Rover P6B 3500 V-8 stresses such a procedure very strongly. The written procedure is bolstered by the claim that the engine oil is not affected by the jelly.
Further reports as the situation develops,
Mike A.
I coat the internals in the oil pumps of most all motors I rebuild with a little moly-based grease or an additive such as STP. Depends on how long the motor will sit prior to firing. The moly will wash out during priming and mix well into the oil.
I would not bother too much about cleaning the internals. Just put some straight 30 in (or possibly a flushing oil/running in oil) and run for 20 miles/ half an hour. then drain and refill with normal and new filter.
Priming should not be an issue. Just take out the spark plugs and turn on starter for a couple of minutes.
I would not use grease it may block the rocker and other fine feed holes.
An Update
After carefully cleaning parts and then re-checking the protrusion of the liner lips at cylinders 1 and 2, it was found that 0.0045" of protrusion had been 'lost'. The copper spacers had settled 0.0015", measured with the same micrometer as was used during the second engine assembly. Interestingly, the brass 0.003" shim that was used in conjunction with the copper spacer, had not 'settled'.
With the shim selection available, cylinder liner lip protrusion has been set to 0.009", a dimension that is reasonably consistent.
As an experiment, the original shim/spacer packs and liners were fitted into the crankcase. The cylinder head, minus gasket, was gently slid home on the studs. The securing nuts/washers were gently seated and then torqued to 14 lb. ft. value. The gap around the joint was checked with feeler gauges and was found to vary from 0.003" through to 0.007". As Neil Moore says, such variation can be seen frequently. With the decided upon shim pack installed, the feeler gauge check showed 0.006" through to 0.009". With that, I am reasonably happy and will (hopefully never!) use this procedure in future. The reason I chose the 14 lb. ft. value is because it is the lowest value on my torque wrench.
There are some water stains in the bores, they pass the finger nail test! The pistons, big ends, oil splash plate, oil pump bottom plate and suction assembly and the oil sump have been fitted. Then it was just too hot in my workshop. More tomorrow!
Mike A.
