A very basic questiin! How is the rack lubricated;handbook appears to indicate a central grease nipple but one is not present on our ('51) Jupiter.
Many thanks
Roger
Steering rack lubrication
114
- Given Name: Roger
rickjowett
- Your interest in the forum: My great great grandfathers cousins were William and Benjamin Jowett, the founders of Jowett Cars Ltd!
1952 Jowett Jupiter E2SAL813
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4 - Given Name: Rick
Re: Steering rack lubrication
I was looking at this over the weekend. Is the fill hole covered by a brass colored nut similar in appearance to the nut for the gearbox oil?
Please advise.
Please advise.
rickjowett
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
If so, what is the proper fill level?
Yes brass nut. I do not think level is specified. I would suggest filling to top and moving the rack each way and filling again. Obviously if it pours out the gaiters check their air bleed hole is on the side not bottom, or stop filling. The important thing is to keep the rack lubricated regularly and to flush out any grit. A thinner oil has a better flush than thick oil or grease. The wear takes place on the aluminium housing rather than on the rack. Also lubricate the pinion via the nipple.
