Steering rack lubrication
Given Name: Roger
Post by 114 »
A very basic questiin! How is the rack lubricated;handbook appears to indicate a central grease nipple but one is not present on our ('51) Jupiter.
Many thanks
Roger
Re: Steering rack lubrication
Nut on top rack. Put some oil in.
What grade of oil?
140 sae
rickjowett
Your interest in the forum: My great great grandfathers cousins were William and Benjamin Jowett, the founders of Jowett Cars Ltd!
1952 Jowett Jupiter E2SAL813
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4
Given Name: Rick
Post by rickjowett »
I was looking at this over the weekend. Is the fill hole covered by a brass colored nut similar in appearance to the nut for the gearbox oil?
Please advise.
rickjowett
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4
Given Name: Rick
If so, what is the proper fill level?
Yes brass nut. I do not think level is specified. I would suggest filling to top and moving the rack each way and filling again. Obviously if it pours out the gaiters check their air bleed hole is on the side not bottom, or stop filling. The important thing is to keep the rack lubricated regularly and to flush out any grit. A thinner oil has a better flush than thick oil or grease. The wear takes place on the aluminium housing rather than on the rack. Also lubricate the pinion via the nipple.
