Diff pinion oil seal
The spring had come off the leather seal.
I took out the seal that had been leaking by welding a puller tube onto it.
The tube took out the outer plate using a two armed puller. The hoop took out the inner retainer using a couple of screwdrivers on the end of the shaft.
If I had realised I should have welded the outer plate to the inner retainer to take them both out at once. Perhaps a seal extractor is available that would avoid welding.
JAMES of Midnight Motors gave me a replacement leather seal. These are available from a SNG Barrett E type Jag 2ha-019 leather ones about £12, rubber ones for £5.
BobCulver
Your interest in the forum: member JCC NZ 40 years +, regular contributor to local mag Flat Four
Given Name: Bob
Re: Diff pinion oil seal
Post by BobCulver »
I have always inserted a couple of self tap screws and levered aginst these to remove
Bob Culver
