break failier
p.p.
- Given Name: peter
break failier
help!!!!
my breaks ar not working!¨ when i start the car, i got no beaks ... i pump several timmes... again and again... then it start to work a short time.... then again no working breaks... hand break working - thanks godness !!! is there air in the breaks ??? the garage made a check, and air bleeding the breaks.... still not working... schall i power air bleeding the breaks or is the problem the break cylinder ??? please give me a clou !!
peter
peter
Re: break failier
Sounds like the Master Cylinder, the unit attached to the foot brake pedal,
These can be repaired - with new seals and oddments - but the safest bet is a reconditioned unit, or of course a new one if you can find one.
They are not difficult to fit but of course you must bleed the whole system when the unit has been fitted - probably a good idea anyway as the fluid may be years old!
Try JCS for a start.
p.p.
- Given Name: peter
Re: break failier
the brake fluid ar new !!!! will see if same jowetter can send me a new one by express delivery .....need it till wendsday eve.... i hope for it !!!! maybe keith got one ????!!!
peter
peter
Re: break failier
See my email.
1. Does the fluid level in the reservoir go down?
2. No, then, if they have been bled properly, it is the master cylinder.
3. If you pump rapidly are there bubbles in the reservoir?
4. If you press slowly, is there any resistance?
Robin Fairservice
- Given Name: ROBIN
Re: brake failure
If you have a Hydro Mechanical system, have you had the front brakes apart? If so, how did you position the springs? If you did what I did and hooked the top spring from one shoe to the other then that may be your problem. The top spring must be hooked from one shoe to a peg on the back plate.
p.p.
- Given Name: peter
Re: break failier
its the master cylinder !!!!!!!
try to fix it .... maybe the rubber ar stick together in the strong winter time - now its trorn...
coming weekend is a raid with diabled kid's ....hope i do not missing it.....we not got so many car's , there need me.- ah- rhowina...
robin - the spring position is correct ! i checkt that !!! thanks for the
peter
peter
Re: break failier
Peter, Is your system full hydraulic or hydro mechanical?
p.p.
- Given Name: peter
Re: break failier
hydro mechanic
Re: break failier
I do not have spares of that master cylinder. I think the seals are different to full hydro.
Re: break failier
Hopefully Bill Lock will be sending spares in time to fit before charity event this weekend.
p.p.
- Given Name: peter
Re: break failier
now i got the problem - so i hope -
the rubber sealing was to small - ca 3mm - two copper washer will solfe the problem........ ( the old master break cylinder hade a rubber sealing 3mm larger)
fix the lot - bleeding - and have a tray.....this afternoon.....
peter
peter
p.p.
- Given Name: peter
Re: break failier
the two copper washer is not working !!!!!!!!!! but i fund a reserve rubber seal in my spare part box.... it fits !!!! is 8 mm , just the rigth one
tomorrow a test drive
and if all fails.....bill send me the parts i need by express delivery...
keith organise me the lot...the JOWETTERS conection
peter
peter
Robin Fairservice
- Given Name: ROBIN
Re: break failier
If all fails I have a spare master cylinder,
p.p.
- Given Name: peter
Re: break failier
thanks robin..... the world wide jowetter's conection
i hope it will be fixed !! by the old county "europa" conection....
but good to now it will be a plan "B" ready....
peter
peter
p.p.
- Given Name: peter
Re: break failier
well..... the new rubber is not working....
now i hope the post delivery from bill will do the trick.....
tomorrow i see the parts.... will inform you about the process
or the plan "B" have to get moving.... robin have to play angel....a cross the big pond.....robin please stay alert....
im still in the good spirit.....
peter
peter
