Woodruff key.
TedAllen
Given Name: ted
Woodruff key.
Post by TedAllen »
Hi, Can anybody help me out with the 'Woodruffe key' that locks the Javelin rear brake drum to the halfshaft please. Mine has dropped out whilst I was sorting out the n/s brake and I can't for the life of me find it.
I can make one if neccesary but an original would be good. Strange thing is, I have a spare drum which may have one in but I can't find that either !
Ted
Hi Ted,
I would expect someone will send you a key quickly, but anyway -
I noticed some woodruff keys on Ebay, but they were for the Javelin oil pump. Don't know whether they are the same size as you require but the Ebay number is:-
Item number: 230300441431
TedAllen
Given Name: ted
Post by TedAllen »
Thanks for the thought Tony.
The wheel key is about 10 times the size of the oil pump one.
Dimensions are Square steel bar 6.5mm X 6.5mm X 25mm.
B&Q do a similar steel bar but it is 7mm square so the options there for a bit of vigorous filing !
Ted
Hello again Ted.
Thought as much, but it was interesting to see that they were made from, and I copy the quote -
made from key-steel BS 970: 080M30 .
How does the B & Q steel match up to these specs, and does it matter?
Yes it matters. The key can take a large shear particularly if the taper has grease on it or is not tight. Remember remove all oil from taper and bore before fitting.
Tim Neville
Post by Tim Neville »
Yes, you most certainly do want to use the right steel. I note the oil pump keys mentioned are made from BS970 080M30. I would have thought that for a highly stressed key such as for the rear hub 080M40 would be more suitable, as per the tables from www.roymech.co.uk (a very useful resource).
TedAllen
Given Name: ted
Post by TedAllen »
Just a public note of thanks to Len Johnson who rang me to say he had a spare and it arrived in the next post. Thanks Len....thats what it's all about. :D
Ted
