SC Rebuild
SC Rebuild
SC Rebuild g_id=11136,_ /Public/KeithClementsPublic/SC Rebuild,_ Forumadmin,_
CutOff
Cut off switch will move to the right.
Positioning the battery cut off so it is accessible to driver and passenger.
Battery cut off g_id=12170,_ /Public/KeithClementsPublic/SC Rebuild/IMG_9891.JPG,_ Forumadmin,_
Boot lid support
repositioning support to fit boot.
Support had to be moved to raise nearside slightly.
boot lid support g_id=12176,_ /Public/KeithClementsPublic/SC Rebuild/IMG_9893.JPG,_ Forumadmin,_
Amy\'sClutchGasket
Amy made the gasket between clutch and gearbox
She alos made the water transfre gaskets.
gasket g_id=12221,_ /Public/KeithClementsPublic/SC Rebuild/Amy_sClutchGasket.JPG,_ Forumadmin,_
FittingTheBox
Fitting the gearbox.
Fitting the gearbox. This was after finding the correct clutch ball and widening the brass bell housing to accomodate it. Then realinging the clutch plate before finally persuading the input shaft to slide home.
Fitting Gearbox g_id=12224,_ /Public/KeithClementsPublic/SC Rebuild/FittingTheBox.JPG,_ Forumadmin,_
PetrolPipe
Petrol Pipe photos before dismantling.
Petrol Pipe photos before dismantling. For ease the aluminium panel was cut as a new one was being made. The rubber pipe needed surgery to remove.
PETROL PIPE g_id=12227,_ /Public/KeithClementsPublic/SC Rebuild/PetrolPipe.JPG,_ Forumadmin,_
PetrolPipe2
More detail of Petrol Pipe
More detail of Petrol Pipe. This shows the metal and rubber draft excluder needed because there is so much movement between chassis and body so the hole in rear panel needs to 2 cm diameter larger than pipe.
g_id=12230,_ /Public/KeithClementsPublic/SC Rebuild/PetrolPipe2.JPG,_ Forumadmin,_
RearPanel
Fitting the rear panel
g_id=12233,_ /Public/KeithClementsPublic/SC Rebuild/RearPanel.JPG,_ Forumadmin,_
RearPanel2
Rear panel detail
Rear panel detail. Trial fitting to check alignment of hole. Hole was tight fit to pipe at this stage and was then widened.
g_id=12236,_ /Public/KeithClementsPublic/SC Rebuild/RearPanel2.JPG,_ Forumadmin,_
RearPanel3
Rear panel detail
Rear panel detail. Note the old wiring loom was fitte to check dimensions. I am going to be intrigued this week to see if the loom ordered from JOAC fits.
g_id=12239,_ /Public/KeithClementsPublic/SC Rebuild/RearPanel3.JPG,_ Forumadmin,_
SwitchPanel
Switch Panel
Switch Panel. Picture to see where to fit fuses and relays.
g_id=12242,_ /Public/KeithClementsPublic/SC Rebuild/SwithPanel.JPG,_ Forumadmin,_
Engine in
Engine in even without mountings
Left one layrub bolt out so as to allow engine to be up at front
g_id=12487,_ /Public/KeithClementsPublic/SC Rebuild/IMG_0009.JPG,_ Keith Clements,_
Pipe draft excluder
Pipe draft excluder
Modified with piece of pond liner. Stuck on saves making a metal plate and screws
g_id=12490,_ /Public/KeithClementsPublic/SC Rebuild/IMG_0008.JPG,_ Keith Clements,_
Boot compartment
Boot compartment ready for fixing
g_id=12493,_ /Public/KeithClementsPublic/SC Rebuild/IMG_0010.JPG,_ Keith Clements,_
Engine mount bracket
This is the one we have; so need the other side
g_id=12499,_ /Public/KeithClementsPublic/SC Rebuild/IMG_0015.JPG,_ Keith Clements,_
