Right one of the holes in my dynamo has serverly stripped thread. Its too short a hole to tap a new thread into it so I've come up with an idea have yet to try it out tho but here goes.
I thought about using a giant duble clip if thats what they are called and spliting it at the locking mechanism end and lengthening the toothed strip and then riviting or bolting it to the the 2 holes on the coil mounting base, then connecting the two ends like a normal duble clip around the whole dynamo and doing up the screw fixing tight
Does anyone reckon that would be a good idea? or even using the remaining good hole and bolt and putting the joing rivit through that bolt to give it a little more support.
Dynamo coil mountings
