Front Brake Expanders
ajg1722
Your interest in the forum: Current restoration projects: Bradford CC Truck, 1939 Tatra 57b.
Also have 1953 Ariel Square Four, 1958 Velocette Venom, 195? Panther M100, 1963 Standard 7cwt Van, 1963 Standard 7cwt Pickup, 1976 MZ TS250/1, 1984 MZ ETZ250, 2001 Toyota Hilux, plus a couple of CZ 175 bikes, all variously running or awaiting restoration.
Given Name: Andrew
Post by ajg1722 »
According to the parts book, Girling front brake expanders are handed. Delving a little deeper, the difference is in the draw link - part nos. 6645/24 and 6645/25.
My problem is, in overhauling an axle set, there appears to be no difference between the sides. In fact, I've looked at 6 front expander units which I have, and they're all the same! So a number of questions: Are they really the same? If they're not the same what's the difference? And which side do I have?
Someone out there must have come across this one before,
Hope you can help,
Andrew G.
ajg1722
Given Name: Andrew
Re: Front Brake Expanders
Post by ajg1722 »
Have now dismantled and cleaned everything, and I think I've answered my own question. Correctly assembled and installed, the draw links from the front expanders should point downwards approx 25 degrees. But viewed from above, the draw link should point towards the REAR by about 10 degrees.
Andrew
