drawing of 1936 rear suspension attached
1936xxMarcelK
- Your interest in the forum: One Jowett 1936, i restore at present.
Some mopeds particular Kreidler and ZÜndapp - Location: 74417 Gschwend
Hello k. rogers
ok thank you.
No, in the heck there was only the remains you can see in the photos.
Hello p.p.
Thany you for the ebay nr. nummer, but i was to late, the article was already ended...
I have founded an LUVAX shock absorter on ebay (nr.:121183954425http://www.ebay.de/itm/121183954425?ssP ... _72wt_1042), but I think the coupling rod is not suitable for my Jowett,
Or do you mean it is the right?
Thank you!
Hello george
Thank you for the drawing!
It's a great convenience
Kind reguards Marcel K.
ok thank you.
Sorry, but what do you mean?, I dont´t understand.are any present on your car?
Hello p.p.
Thank you!
Hello george
1936xxMarcelK
Hello, If anybody have to sale a LUVAX shock absorter for my Jowett, please let me know!
Also I need:
one brake drum; and brake pads for all four Brakes
cylinder head gasket; exhaust manifold gasket; aspiration hole gasket
each two pieces
four spark plugs
two coupling bars with rubber mount ( on the front shock absorter )
all mountings for the flat spring
do you know, where i become these spares, perhaps new?
Do you have to sale one thing, please let me know!
Kind Reguards
Marcel K.
Also I need:
four spark plugs
Kind Reguards
Marcel K.
by ''aspiration hole'' I presume you mean the joint between the induction pipe (or manifold) and each cylinder. I would recommend the use of 2 gaskets for each side i.e. each joint . The extra thickness prov;ides a little bit of flexibility that can help prevent the flanges cracking when tightened down.
Also if replacing the cylinders onto the crankcase only tighten them VERY loosely - then tighten the induction pipe flange nuts - then fully tighten the cylinders.
Hi Marcel - I would think that all the parts that you require are available the rough the club spares scheme of ' Jowett Car Spares ' - they are only contactable on a Monday evening - details are in the Jowetter magazine - if you would rather one of us over here contacted them on your behalf - that can be arranged - just let us know
1936xxMarcelK
Hello george
Thank you for that offre! I have prepared all things, that I will send to you! Perhaps send next week.
before, I will send you a privat message!
Here a picture from Jowett news in Gschwend
Marcel
Here the red arrow shows the joint, I mean: Hello Chrisby ''aspiration hole'' I presume you mean the joint between the induction pipe (or manifold) and each cylinder.
Marcel
I agree with George, Marcel.George wrote: Also if replacing the cylinders onto the crankcase only tighten them VERY loosely - then tighten the induction pipe flange nuts - then fully tighten the cylinders. George
When fitting the manifold to the cylinders, using two gaskets for each side, and perhaps some sealant, first loosen the nuts that hold the cylinder flanges to the engine casing on both sides. Then tighten the nuts on the manifold. This will allow a little movement while tightening the manifold. If you do not do this, the ends of the manifold may be broken as you tighten their nuts.
When the manifold is ok, then tighten the cylinder flange nuts to the engine casing. I was told to use flat washers under the nuts, and not spring washers. The cylinder flange nuts have to be VERY tight.
You will have to check the tappet gaps again.
Your second photograph shows just how far the restoration is progressing, and it looks wunderbar!
Marcel - Great to see the progress
[quote="1936xxMarcelK"][u][b]Hello george[/b][/u]
[quote]by ''aspiration hole'' I presume you mean the joint between the induction pipe (or manifold) and each cylinder.[/quote]
[attachment=1]DSCF1408.jpg[/attachment]
Marcel[/quote]
yes - that's the joint between induction pipe and cylinder! Use 2 gaskets on each joint I.,e 4 in all
Marcel[/quote]
1936xxMarcelK
Thank you for explaining again, ... on weekend i´ll go to my neighbor, he can exacly translate the text for me.
I won´t make a mistake and mounting corectly, so you said!
Tank you, i´m very happy, too!
How do you understand the word ground and filler ? (thema painting)
Greetings grom Gschwend, Marcel
1936xxMarcelK
Jowett Forum:
Hello,
In the next time i will buy 5 new tires and inner tube.
I have researched, the original tires of Jowett are 4.50-19 Dunlop. As well as my Jowett.
What tires do you drive? And what producer?
The Dunlop 4.50-19:
Price 180€ circa: 150UK£ Whats the price in UK?
alternative:
The Waymaster Sport 4.50-19:
Price 130€ circa: 110UK£
alternative:
The Excelsior Silverstone 4.50-19:
What do you think what kind of tire i should buy?
Ordinal would be the dunlop, is that right?
Kind Reguards
Marcel
Hello,
The Dunlop 4.50-19:
alternative:
alternative:
Kind Reguards
Marcel
Hello Marcel.
I bought 4 Waymaster tyres recently for my 1934 saloon. I do not drive many miles in the car these days, so I hope they will not wear out.
The price was similar to yours.
The company I used was Vintage Tyres Supplies, and they sent them very fast. But of course that is in England.
It is VERY important that you make the 'toe-in' correct on the front wheels, or the tyres will not last.
The handbook will show this I think, but the distance between the front of the wheels should be 1/8" closer than the measurement at the rear of the front wheels.
If this is not set correctly, there will be much wear on the tyres in a very short time.
Did you send your list of Jowett parts to Jack?
Does Jowett car Spares have all you need?
Best wishes,
Best wishes,
1936xxMarcelK
okay, I think, I will buy the dunlop tires!
yes, if the frame is in running condition, I will bring the axiale in position and adjust lane!!
The packet will arrive the packing station on monday, and goes to journey to you!
all screws i need are inside and a list of car spares, too.
Kind Reguards
Marcel
Kind Reguards
Marcel
Hi Marcel.
I will look out for your parcel on Monday.
Keith C.
Keith C.
Hi Marcel,1936xxMarcelK wrote:okay, I think, I will buy the dunlop tires!
Kind Reguards
Marcel
You might want to consider JCS for tyres - they have a relationship with tyre retailers and might be able to get a better deal for you. They may also have opinions on the quality of the different tyres available for your car.
Well done on making so much progress, great to see projects moving along.
