Early Javelin Restoration
Re: Early Javelin Restoration
The lower section of rust perforated chassis brace was repaired prior to the tacking in of a new outer chassis rail section Welded in Cleaned up & trial fitting of the outrigger / jacking point
Front section of the sill / lower A post look ok But there is lots of grot along with many poor previous repairs on the underside Floor pan area looks ok but is very thin and with lots of pinholes / poor repairs
Removal of the lower A post section reveals more poor repairs Floor pan part removed to aid fitting of front outrigger - a large section of the offside floor pan shall require replacement Measurements to the A post to allow reference data when fabricating the repair sections
Just because you have what looks like good metal on the top - will not guarantee good metal on the reverse side Small section of the new outrigger requires work to reduce the size where it mounts to the chassis rail / box section Lots of rust and thin metal removed and a little more still to be chopped out before the rebuilding can commence
Managed to find a spare afternoon to continue the progress - I needed a reference point to get the sill alignment correct - but this means yet more cutting back of what looks like sound metal on one surface But on the rear are layers of rust compounded with poor previous repairs
Last edited by Chris Spencer on Sun Aug 18, 2013 10:31 pm, edited 1 time in total.
The rust theme continues Joined by the poor repairs theme
Lots of cutting later in order to access rust prone / poor repair areas - and some new metal could start to go back in Lower leading edge section of A post made up and welded in, the front outrigger had to be trimmed and re-welded to ensure a close fit with the chassis - once I was happy with the fit I tacked the outrigger on - careful measurements were made to ensure that new sections were positioned correctly Lower section of inner wing / wheel arch was cut away - the site of previous poor repair New section fabricated and welded in
The sill could now be trial fitted With a little trimming a good fit was achieved So the sill can be tacked into place and new sections made for the floor pan and the bottom of the A post
Floor pan being patterned Repair section fabricated
Existing floor pan cut back and prepared for new section Welded in & cleaned up
The front outrigger could now be fully welded into place and the new floor pan section spot welded to the inner wing / wheelarch Sill tacked on and ready for doors to be rehung in order to check clearance / door gaps
Doors hung and sill clearance checked
However - much fettling is required on the doors / apertures in order to ensure the correct gapping is achieved
First I needed to secure / complete the A post repair to the sill Next will be the B post / sill repairs - once these are complete I can start to make the adjustments to the panel gaps but as this requires a certain amount of force I need to have some support in the B post / sill area
More progress
Rear sill / B post repairs in the making Front sill / B post completed
