Jupiter gear change column
conrod
Post by conrod »
Does anyone have a surplus gear change column for a Jupiter or details on how to convert/ extend a Javelin one ?
Re: Jupiter gear change column
Details of conversion are in JowettGallery and JowettTalk I think. Try searching. If you do not find then Drummond Black demonstrated at Gaydon JAW.
Given Name: Drummond
Post by Drummond Black »
Just give me a call or PM and I can assist.
Drummond
jowettgeoff
Post by jowettgeoff »
Which reminds me Drum, did you ever get chance to do the one I gave to you last year? My original one seems to be surviving, but one day ... :(
Thanks,
Geoff
Given Name: Michael
Post by Mike Allfrey »
G'dday from the Damp Sunny South,
I have converted a Javelin gearshift column to suit a Jupiter. This was some years ago and I think I wrote it up somewhere. Will have a look.
Main points are that, in both columns (inner and outer) alignment must be kept to ensure that the gear change lever and the selector change helix are in the correct relationship with the pivot housing for the hand lever assembly. Being just a small amount out of position will cause the gear lever to 'hang' in the incorrect attitude. This is critical!
I set up each column in vee blocks on a surface table and used a long straight edge to scribe a line along each component and, before bronze welding the extension pieces into place, took great care with the alignment of the long scribed lines. A long scribed line helps keep the alignment absolutely correct.
When it came to painting the outer column, I simply smoothed and putty-filled the line. That has been successful.
One point noticed since the conversion is that, when pulling the hand lever towards the steering wheel, it feels slightly heavier. Others who have driven the car have not yet commented on this.
I will see if I can find what I wrote and post it.
Best wishes to all of you,
Mike Allfrey - E0 SA 42R.
You may like to look at how I did it.
viewtopic.php?f=163&t=5217&p=25467&hili ... UMN#p25467
Particularly this sequence starting with the alignment
