Has any one got a source for the front suspension upper link trunnion outer washers (part no J54474 in the parts book) ?
These should be anti rotation washers with a D shaped hole.
I got a full set of bushes & washers from JCS and they have provided 4 off round holed washers with a 1/2" hole, suitable for the main section of the spindle. Once the bushes are installed and compressed the outer washers sit on the 3/8" threaded portion of the spindle. I have tried assembling the link using the 1/2" washers but when I rotate the upper spring arms by hand I can see the slotted nut moving and bending the 1/16" split pin. I don't think the split pin would last very long on the road without the correct washers.
John Dolphin
E3SA 887
Rubber Bushed Front Suspension Upper Link Trunnion Washers
John Dolphin
John Dolphin
E3SA 887
E3SA 887
Re: Rubber Bushed Front Suspension Upper Link Trunnion Washe
You could weld the flat in. But a good spot, and worth everyone to check. Also suggest using Loctite on nut.
- Given Name: Drummond
Hi John, Am I correct in assuming that the metalastic bushes you received from JCS do not have a steel disc on the larger end ?. The original metalastic bushes fitted by Jowett had a full steel thimble and the 1/2" washers are supplied to replace this and make up to the original dimension. JCS assume that you will refit the original " D" holed washer which you rightly state are required to stop the nut attempting to turn. Do you still have the original D washers ? I might have some second hand ones if needed. I made some stainless steel ones for the Javelin to try and stop them rusting. ( a few hours with a small file to make the D hole- and you require them to be at least 3mm thick ). I always fit Stainless Steel 3/8" BSF nuts in this area and cut a slot with the hacksaw for the split pin. Give me a shout if I can assist further.
Drummond
Drummond
John Dolphin
Thanks for the replies.
You're right Drummond the replacement bushes don't have a steel disc at the larger end. The washers provided by JCS are 1/2"x 1 3/16" so they are a bit loose over the 3/8" thread. Unfortunately I don't have the original D washers as they were badly corroded and I threw them away many years ago after stripping the front suspension.
I am going to have a go using Keith's suggestion and spotting some weld in to create the D hole. I have ordered some M10x30mm stainless washers from eBay which should do the job. I'll put some photos on the forum if I manage to come up with a reasonable solution.
John Dolphin
E3SA 887
E3SA 887
John, thanks for reply. Unless you have manages to get ultra thick ones I doubt that they will last. That area does take a bit of a thrashing as the car bumps around. I have found two good S/H ones, so far, will probably find others in the garage. As I said they require to be at least 3mm or 1/8th inch thick. Give me a call if you wish, Number is in the Jowetteer.
Drummond
Drummond
Never throw anything away, or at least until you have rebuilt the car. Ask Amy and Jack!
John Dolphin
I had a good chat with Drummond on the phone who explained some of the finer points of the late type suspension.
He kindly offered to send me a set of secondhand anti rotation washers. Now I have them I can see that they're fairly substantial. I mananged to find some M10x30mm washers on eBay which are 2.5mm thick. Although they are a reasonable match for OD and hole diameter they look a little on the thin side.
I guess at a push they could be used to make new anti rotation washers but as Drummond has sent me a set I'll use the secondhand ones.
Once again Jowett Car Club members have shown great generosity regarding information and parts.
John Dolphin
E3SA 887
E3SA 887
