Briggs and Stratton genny.
rob needs
Post by rob needs »
A bloke gave me a genny it has the Clarke name on it and its a 5hp,110 and 240v.Give it a clean up and it should start he said.Thing is,how do you cut the engine as i cant see no on off switch,like on another i have.
Do i just pull the HT lead off :?:
rob needs
Post by rob needs »
I've sorted it,the cut out was a strip of metal that you press against the top of the spark plug.It had snaped off and all that was left was under a head bolt.
Return to “Natter”
