Ladies and Gents I have no connection with the vendor but some unused pistons for a 1937/38 8 Hp have appeared on Ebay
http://cgi.ebay.co.uk/Jowett-7G-8G-946c ... dZViewItem
The above link should take you there.
New 8 HP pistons
Alastair Gregg
D7 CB 6079 CVG 166
New 8 HP pistons
Compliments of the Season,
Alastair Gregg
Alastair Gregg
Tony - yes , so may be of use to somebody, however the official JCL max overbore is 40 thou . I once had a 60 thou oversize pot blow asunder so to speak on the non watercooled part about an inch up from the flange . It carried on running & I was able to travel slowly abut 2 miles home firing on both pots & with the conrod visibly moving in the inch or so gap in the pot and with the gear leaver moving from side to side. Back on road in well under an hour with brand new pot & piston I happened to have! - So perhaps caution is called for if thinking of 60 thou oversize.
7 hp standard size 2.970
8hp 3.030
difference .062
8hp 3.030
difference .062
