fuses
strathmore22
Your interest in the forum: New owner of Jowett Javelin 635XWE. Also own Eunos Roadster 1991 and Mazda 323f 1994. I first owned a Javelin when in New Zealand in 1960/61. I liked it so much that I bought another one when I returned to the UK and owned that one from 1963 to 65.
Other interests include authorship of books all available on Amazon UK, the latest one being "The Steamer", also playing piano and singing on YouTube and TikTok - see Roger Lancaster Piano and choose popular.
Given Name: Roger
fuses
Post by strathmore22 »
Hi. I have just bought a Javelin 1953. I would like to know where the fuses are situated, which one is which, what type of fuse each one is and what the amperage is of each one. I find the technical information provided by the club is so extensive that I am left rather bewildered. I owned Javelins between 1960 and 1964 but have forgotten most I ever knew.
Re: fuses
They are 35 Amp.
Their location depends on the model but there are usually two either on the outside of the regulator or in a separate small box.on the inside of the bulkhead. They often suffer from oxidisation so a fault can sometimes be cured with fine emery paper.
Page 84 of this manual.
download/file.php?id=25520
The 1953 model used a different regulator to this early one.
Item 2575 in this page from the parts book.
download/file.php?id=6899&mode=view
strathmore22
Given Name: Roger
Re: fuses
Forumadmin wrote: Mon Oct 06, 2025 6:41 pm They are 35 Amp.
strathmore22
Given Name: Roger
Re: fusesThank you. I have found those three, I thought there would be others.
strathmore22 wrote: Tue Oct 07, 2025 10:39 pm
Re: fuses
Hi Strathmore22, you have found all of them! Compared with modern vehicles, the Jowett company obviously wasn't too concerned with H&S. Fuses were few and, being 35A rating, you really had to have a serious problem before they blew! I find the steel clips holding the fuses get corroded first and mind they don't get brittle and just fall off! The RF95 regulator, where the fuses are fitted, usually suffers from internal corrosion on the points and you might wish to consider fitting a replacement unit, as these often are the cause of a 'no-charge' condition.
All the best, David
strathmore22
Given Name: Roger
Re: fuses
Many thanks David.
