Jumping out of second gear
alexander
- Given Name: Dave
Suggestions please drove the Javelin today and for the first time , when changing into second gear it jumps back out a couple of times. Could this be adjustment of the two little pegs and springs on the gearbox .
JUP
- Your interest in the forum: Own Jowetts
- Given Name: Graham
Re: Jumping out of second gear
Suggest you check the gear rods length first - if this is the cause it will only need a little adjustment
I always set the rod length by puting the gearbox in reverse and adjust the gear rods accordingly
Hi Alexander,
There are several methods of setting the lengths of the rods. I suggest you first try the Jowett method set out in the handbook. You will need to find a small twist drill, to hold the selector shaft in the correct position. There is a corresponding hole in the gearbox casing. This locks the selector shaft in the correct position, and you can then set the rod lengths.
Bear in mind though that's with a new gearbox. You have one that's 70 years old, and you may need to apply a bit of tolerance. Personally, I would leave the selector rod detent adjustments alone, until you have tried the rod lengths. Whatever you do, make small adjustments at a time.The whole gearbox is a collection of worn components, and hitting the 'sweet spot', is tricky. I once knew an ex-Jowett Technical Apprentice, who spent months just lapping components on the Jowett-manufactured gearboxes, trying to get them to work. He ended up with a skin condition, that he was sure had been caused with his hands immersed in gearbox oil for months. Your box might have been one of his?
