Could someone please help re the banjo and banjo bolt on the high pressure side of the master cylinder (full hydraulic system)? The parts book specifies gaskets (not illustrated) and I have a slight weep of fluid (silicone) from this joint since rebuilding my brake system. Does anyone know:
a) The correct positioning of the gaskets i.e. where do they go?
b) What they are made of? (I have used ordinary fibre washers which obviously haven't done the trick!)
Don’t I have some fun with this car? Almost as much as Alan Bartlett with his pre-war!
Thanks for your help
