Stale fuel - ethanol?
Today I decided to start my 1930 Long Four in anticipation of a run to the L2B in November.
It was last run about a week ago but would NOT start today. I last put fuel (E5) in about a month back. I always run the engine to empty the carb when not using it again the next day, to minimise corrosion to the float and jets.
I eventually decided the reason must be stale fuel despite having one of those 'metallic' diamond shaped devices in the tank to 'prevent stale fuel'.
So, drain the tank and replenish the fuel, no problem - really?!
The filler cap to the tank was locked solid and only relented when I fitted a 'jubilee' type hose clip to get a better grip.
Fresh fuel and all seems well (for now!).
Just a thought - check that YOUR filler caps have not corroded sold since the last time you put fuel in the tank.
Re: Stale fuel - ethanol?
Hello Ian.
You might remember that I have had petrol problems with my pre-wars in the past, mainly during the winter.
viewtopic.php?p=20128&hilit=water+in+petrol#p20128 might help.
But perhaps your tank might be under the bonnet, and the filler cap could do with a good clean and a smear of copper-ease on the threads.
Done it Tony!
Once bitten...
