Engine Noise & Valve Adjustment - Hydraulic Tappets
trymes
- Your interest in the forum: I now own Javelin E0 10010 (formerly Robin Fairservice's car in British Columbia). I spent some time figuring out a terrible racket in the engine and it will be used in the summers, alongside my collection of British obscurities (well, they are obscure here in N America).
I'll be looking for technical help, spares, and the sort. - Given Name: Tom
All, I haven't properly introduced myself yet, but I am located in New Hampshire, and recently purchased Robin Fairservice's Javelin, E0PBL10010D. It's a LHD car that spent its entire life in British Columbia until this summer!
Anyhow, it is currently running engine number E0PCL11308, with E0PBL10010 also rebuilt on a dolly in the garage. Both engines, to my knowledge, have hydraulic lifters. When its running, the engine has a rapping sound, above and beyond what seems like what I would expect a normally tappety engine to sound like. I'm familiar with the phrase "a noisy engine is a happy engine", but this seems excessive, almost like someone tapping a hammer.
Before I get overly nervous, I figured I would adjust the valves, but just as I was comfortable with the process for solid lifters, I realized that I have hydraulic lifters. Can anyone point me to a good explanation of the process? I am comfortable with rotating the engine to 360° past the point where the valve is fully compressed, and from there the rocker is on the valve stem with no gap, but I can push it back into the block. Here's a quick video I posted before showing what I'm seeing. Apologies for poor videography and I think this was before I realized I had hydraulic tappets.
Tom
https://youtu.be/gmw-Ela5jko
This is also a video of the car from before I bought it. You can hear it run, but it's hard to hear the rapping I'm concerned about, except when the car revs up, and when it's away from the camera. https://youtu.be/Tf5ykePopjE
Tom
Re: Engine Noise & Valve Adjustment - Hydraulic Tappets
Hi Tom ,
Welcome to the club and your recently acquired Javelin.
I think you should find something useful in this early manual in Section 22 Page 14 and Section 90 page 30
viewtopic.php?t=6092
Yes there is far too much play there and may suggest a dry tappet.
Scott, Neil and I visited Robin on our way up to the Arctic Cicle from Los Angeles in Scott's Javelin.
Good to see it has another caring owner.
trymes
Many, many thanks, Keith! I think I now have more questions than when I started!
For a start, how does the ball hold against the seat if gravity is pulling it the other direction? A spring, I suppose, but I didn’t see that. I suppose that the flow of oil could force it out, but it seems quite imprecise to my uninformed eye.
Beyond that, the instructions are to set the clearance to 0.06”-0.09” when dry, but once the engine has been started and oil reaches the tappets, how long does it take for them tappets to drain? Or do they drain at all? Some of mine seem springy like in the video, while others seem rigid.
I have a sinking feeling I’m going to need to take this thing at least partially apart..
trymes
I should add: I have a spare engine, how difficult is it to get at the tappets to get a feel for how they work, etc? There’s a metal cover that comes off and provides decent access, especially when out of the car, no?
Tom.
I have no experience with the hydraulic tappet unfortunately. Hopefully the few that have will respond. You and I can also use the search archive facility as I am sure this must have been answered before. https://jowett.net/searchserver.php
The tappet covers with the two dozen set screws allow access to the tappets.
I would try turning the engine over with the starting handle and follow my procedure here. viewtopic.php?p=43335#p43335
This may show if the springy ones turn to rigid as they rise on the cam and conversely.
My guess is the oil should not drain off within an hour.
Search Archive with 'hydraulic tappet' search provided 230 results:
viewtopic.php?f=161&p=38536
Section 11 Page 9 and 13 /10
viewtopic.php?p=29877#p29877
Page 5
download/file.php?id=23908
Page 4 JowettJive-19.pdf
download/file.php?id=23703
Page 63
download/file.php?id=3621&mode=view
Note to find the topic from the Search Archive copy the number after P= into an URL that looks like this. Replace the 43184 in both these places.
To find the actual pdf you may need to use the file name and then download it. e.g. JowettJive-19.pdf
The URL link can be copied from the topic using Right Click on the picture or icon in the topic so that it looks something like this.
In the following you can simply go to the Jowetteer forum viewforum.php?f=77 and find the relevant year and then document.
Page 7. P=44112_Jowetteer1963-02.pdf
Page 8. P=24942_Jowetteer1968-08.pdf
Page 2. P=24951_Jowetteer1990-06.pdf
Page 7. P=44113_Jowetteer1962-06.pdf
I am in the process of moving the Search Server from my home laptop to the clouds to provide better response, so you may notice an interruption of service.
Page 5
Page 63
Code: Select all
https://jowett.net/forum/viewtopic.php?p=43184#p43184The URL link can be copied from the topic using Right Click on the picture or icon in the topic so that it looks something like this.
Code: Select all
https://jowett.net/forum/download/file.php?id=23703Page 7. P=44112_Jowetteer1963-02.pdf
