Ariel
Barry20383
Given Name: Barry
Ariel
Post by Barry20383 »
Have fitted a radio to my 1953 Javelin and now need to fit an aerial. I saw an article saying the Javelin originally had the aerial fitted on the chassis under the car is this correct. If this is correct it would be easier to fit than in the roof having to remove the headlining.
Thanks for info.
Re: Ariel
Hi Barry,
I believe Javelins had an aerial fitted on the centre line of the roof, just above where the rear view mirror is fitted. Like most Javelins, mine has a cover plate fitted to the dash, where the radio would have been fitted.
In my experience with electronics, fitting an aerial beneath the car would not look like an ideal site for reception. However, with modern DAB radios you never know? Perhaps worth experimenting, before you go to the trouble of drilling a hole in the roof?
In any case, you will probably need to fit some additional components to suppress interference. The cars were pretty 'dirty' for radio reception. Try a capacitor ( 0.2uf or similar ) on the live side of the dynamo, similarly on the 'hot' side of the contact points. Also, resistive plug caps should help.
Re: Ariel
Where did you see that article? Anyhow first look at the radio you are using, Original radios were long and medium wave amplitude modulated, not frequency modulated or digital. A DAB radio will work with a stick on the windscreen aerial.
The radio in my Jav has the aerial on the roof many pics of it at Goodwood and is 1970 vintage .
