This sequence may assist those joining the JCC who are existing members of other Jowett Clubs.
As a member you have privileges and a tailored MENU within Member Services.These are defined by the ROLE you choose when you start a session.
When you click on the link in the activation email sent to you when you register you should be presented with this after you enter your password.
1. Confirms you are not in JCC.
2 Confirms you are in JCCNZ
So click 3
4 Confirms you are using ROLE NZMember
So click 5
6 The system has transferred your registration contact details , either correct and then click CHECK CHANGES or
7 When all OK click NEXT STEP
8 The next screen confirms the record created for you.
9 Enter your address. The pink messages are warnings, either correct or ignore
10 Click CHECK CHANGES
11 The pink messages are warnings, either correct or ignore . But click one of the buttons to tell the system to auto correct or ignore.
13 Either repeat the CHECK CHANGES or if you are satisfied click NEXT STEP
14 The system will confirm it has updated your record with the address and
15 warns you you need to chooses a SECTION
Continue through the next steps Checkin and Next Stepping until you come to Payment screen
Joining For Members of other clubs
Restarting the session
If your session times out then when you restart using your activation link you will be presented with a ROLE choice.
6 Click ASK PASSWORD Now you have a choice of ROLE as you have a record in the UK list
7. So change your role to UK LAPSED 8. Confirms your new ROLE
9. Click MENU 10. Check you are on the step in the Joining Process.
11. COMPLETE JOIN 12. The system takes you to where you left off rmeinding you you need to choose a SECTION
1. This is what you get if you time out but hopefully you entered a password so can reuse your activation link.
Note that you can transfer the link (3) to a desktop shortcut, alias or bookmark rather than finding the activation email (4)
5 Enter password6 Click ASK PASSWORD Now you have a choice of ROLE as you have a record in the UK list
Users browsing this forum: No registered users and 3 guests
