Shackle pins - 'any old bolt won't do!
Thanks to KC I have just had a look at one of the old Jowetteer magazines that he's kindly put on JowettTalk.
There is a wealth of knowledge to be gleaned from the technical contents of these publications.
Below I've copied just such a one which will show you what I mean:-
'I have been looking into the manufacture of shackle pins for vintage Jowetts. The first problem to be considered is the type of steel for raw material. I have contacted several Club members; a Jowett owner in the VSCC; Dr Shapland the spares representative of the VSCC and also Sanderson Kayser, steel manufacturers in Sheffield.
The recommended specification is EN24T, a nickel chrome vanadium steel with a tensile strength of 55 tons per square inch. The advantage of this specification is that it can be machined to size and does not require a subsequent case hardening operation.
As these pins are a safety critical item I propose to buy prime Sheffield steel from Sanderson Kayeer complete with a chemical analysis certificate.
The bar would be obtained in round form, then there are seven machining operations to produce shackle pins to original size and specification.
A drawing of the original pin is shown below. (There are different lengths for each car and I would appreciate your help on length measurement)'.
Re: Shackle pins - 'any old bolt won't do!
This shows the snippet of the article as found by the Search-archive service in Member Services when searching for 'shackle pins'.
28 other articles were found.
The listing preceding the document this extract was in had more occurrences of the search words.
Note that I have erased any sensitive information from the images as this post is in public view.
