Facebook login
Facebook login
I have added the ability to login to JowettTalk from Facebook.
Please respond here if this was successful or unsuccessful for you.
The authorization process will then ask you to attach the external account (your Facebook one) to a JowettTalk account for which you must know the username and password! You only need to do this once.
Your email address on Facebook does not need to be the same as that registered with JT, but please make sure you CAN and DO read the emails that may be sent to the email address registered on JT.
If you do not have a JowettTalk account, then you will need to Register on JowettTalk and set the email address to the one you usually read.
If you do have a JowettTalk account, then the first time you use the Facebook authorization method you will need to choose the JT account you are going to use.
If you have forgotten your JT password, then click the forgotten password link.
If you no longer read the email address on JT you will need to change that by logging in and going to the User Control Panel, Profile.
If you have forgotten your JT username then please contact me telling me the email address you may have used to register and your Given and Family names.
If you have any issues then please contact me.
