Half-round aluminium strips for roof
ajg1722
Your interest in the forum: Current restoration projects: Bradford CC Truck, 1939 Tatra 57b.
Also have 1953 Ariel Square Four, 1958 Velocette Venom, 195? Panther M100, 1963 Standard 7cwt Van, 1963 Standard 7cwt Pickup, 1976 MZ TS250/1, 1984 MZ ETZ250, 2001 Toyota Hilux, plus a couple of CZ 175 bikes, all variously running or awaiting restoration.
Given Name: Andrew
Post by ajg1722 »
Can anyone please tell me the width of the half-round aluminium strips Briggs used for the roof?
Thanks,
Andrew
Re: Half-round aluminium strips for roof
Regardless of what Briggs used you will not find an exact match available in the market and will have to fit what is available - the nail on type roof gutter is no longer available in the correct depth either -the only nail on type one is of quite a narrow profile that does not have enough depth to hide the fabric nailing (The narrow profile guttering is manufactured for Morris Minor Travellers) - the alternative is fit a J type profile gutter
Links to stockists
https://www.woolies-trim.co.uk/product/ ... -aluminium
https://www.woolies-trim.co.uk/product/1683/half-round
https://www.woolies-trim.co.uk/product/1682/half-round
https://www.vintagecarparts.co.uk/produ ... half-round
https://www.vintagecarparts.co.uk/produ ... er-section
https://www.vintagecarparts.co.uk/produ ... p-gutter-1
https://www.woolies-trim.co.uk/product/1260/guttering
The problem with the above suppliers is that they will not post anything over 2 metres in length (even lees than this in some cases)
John Adams Coachbuilding supplies will deliver by the length but have restricted stock width
http://www.commercialbodybuilding.co.uk ... minium.pdf
ajg1722
Given Name: Andrew
Post by ajg1722 »
Thank you Chris for your reply.
However, it's not the gutter I have an issue with. I actually managed to salvage some suitable guttering from a scrap caravan some years ago and have now fitted it. IMHO it looks OK. See photo.
No, the issue is the width of the 1/2 round strip that goes where the tin stops and the fabric starts on the roof. For a van this is above the windscreen and for a truck (my case) all around the rubber/fabric bit in the middle. Now I do have some 1/2 round alu, which is 19mm wide. But this a) LOOKS too narrow, and b) doesn't look like it's up to the job. Hence my question.
BTW I have no problem sourcing 1/2 round alu in various widths locally
I think I used 19mm on the last Bradford roof that I did - you could probably up this to 22mm but I think 25mm would look too wide
