The original Bradford Truck cab rear wall was a sheet of thin ply to which on the outer surface was bonded a thin sheet of aluminium. I understand this was a standard commercial product at the time, but sadly no longer available.
My problem in trying to recreate this is finding a thin sheet (0.5 or 0.8mm) of alu that is big enough, without having to buy industrial quantities of the stuff. The size required is 1100x1050mm, but every supplier I have spoken to so far will only supply an individual sheet where one dimension is 1m.
Anybody any ideas?
Cab Back Wall
ajg1722
- Your interest in the forum: Current restoration projects: Bradford CC Truck, 1939 Tatra 57b.
Also have 1953 Ariel Square Four, 1958 Velocette Venom, 195? Panther M100, 1963 Standard 7cwt Van, 1963 Standard 7cwt Pickup, 1976 MZ TS250/1, 1984 MZ ETZ250, 2001 Toyota Hilux, plus a couple of CZ 175 bikes, all variously running or awaiting restoration. - Given Name: Andrew
Jeremy
- Your interest in the forum: I now have a CB Bradford kit of parts - one special coming up!
- Given Name: Jeremy
Re: Cab Back Wall
Have you tried Aluminium Warehouse?
https://www.aluminiumwarehouse.co.uk/al ... gleadwords
Cheers
Jeremy
Cheers
Jeremy
Re: Cab Back Wall
My supplier 'Metal Store' stocks a 0.9 sheet that's available in 1250 x 1250mm - they will even cut it to size for you - delivery is normally fairly quick too - link below
https://www.themetalstore.co.uk/product ... heet-0-9mm
ajg1722
Re: Cab Back Wall
Many thanks with the help on this one, I think I'm sorted.
Andrew
Andrew
