As the rebuild progresses I find I am missing the brass rod end of the throttle cable. I have the nipple and clip for the accelerator pedal end of the business, and it would be dead simple to make the rest. Only problem is I don't have the dimensions A and B as in the attached sketch. Can anyone please help out?
Andrew
Throttle cable
ajg1722
- Your interest in the forum: Current restoration projects: Bradford CC Truck, 1939 Tatra 57b.
Also have 1953 Ariel Square Four, 1958 Velocette Venom, 195? Panther M100, 1963 Standard 7cwt Van, 1963 Standard 7cwt Pickup, 1976 MZ TS250/1, 1984 MZ ETZ250, 2001 Toyota Hilux, plus a couple of CZ 175 bikes, all variously running or awaiting restoration. - Given Name: Andrew
Throttle cable
Re: Throttle cable
I have this on my CC pick up, I shall have a measure up for you this evening and post up a photo.
BarryHarding
- Your interest in the forum: Jowett Bradford owner with an interest in older British cars currently have 1937 Jowett 10 hp roadster, 1948 Morris Six, restored but now in only fair condition, 2 CC Bradfords, 1 restored and the other unrestored.
An unrestored 1956 Jaguar 2.4 Saloon. - Given Name: Barry
Re: Throttle cable
The brass is 62mm long and the overall length from the centre of the clevis pin to the end of the brass is 123mm
I would think a few millimeters either way wouldn't matter.
Barry
Barry
Barry Harding
BarryHarding
Re: Throttle cable
I have just reread my post and it might be a bit confusing.
Dimension "b" is 62mm and dimension "a" would be about 45mm and the total length of the whole thing from the centre of the clevis pin including the brass bit is 123mm.
Hope that is a bit clearer.
Barry
Barry
Barry Harding
ajg1722
Re: Throttle cable
Many thanks, job done,
Andrew
Andrew
