What has happened to Jowett Gallery?
What has happened to Jowett Gallery.
I can't find any direct links to it, and any attempt to login, so to say,
through a back door gives an error message that I am not authorised to view
content. I want to add some more pics to my gallery!!!
Andrew
Re: What has happened to Jowett Gallery?
Hi Andrew,
Well quite a lot has happened to the Gallery...it took well over a 1000 hrs to transform it into the Forum (JowettTalk) database .
The story is here.... and in even more detail here.
There is now no separate login to the Gallery as it is all part of JowettTalk.
You should now find it a lot easier to add pictures ( and other stuff) into what was the Gallery, none of which has disappeared but will have been moved around a bit into the structure of JowettTalk.
Your personal album is here. If you have issues adding to it , please contact me.
I notice you have kindly uploaded some articles that perhaps would be better loaded into the clubs' technical library. But you will have an issue seeing the Technical Library as it is only available to club members.
Using the attachment facility.
You can drag and drop pictures into the posting window or use the 'add files' button under the attachments tab below the posting window.
The new system is explained here.
Some advanced notes on attachments are here.
