Members' map.
Members' map.
The members' map has been updated so why not contact those wanting or willing to help get a Jowett on the road?
You will see when you go to the UK First Aid map there is a link to the topic in the Club Discussion section of JowettTalk.
I have added nine new maps. When you click on the links in the topic you need to go through the member validation routine via email unless you came to the JT topic via the UK first Aid map. Then just return to the links and you should see the relevant map.
If you are a club member, you can discuss in this topic.
Re: Members' map and vehicle register
14 people have used the members' services this month which is encouraging.
It is also useful in starting communication with non-members as non-members can also register. Five new members have come about through this initial contact this year.
Other new members have been 'captured' via the jowett.org requests form and the jowett.net contact form.
Note that as well as the members' maps for the UK, NZ and Aus members there are membership detail change and renewal services available for UK members. You can use the vehicle register form to add any detail about a car to improve our knowledge about them. This detail will be sent to the relevant Club Registrar.
