Wanted Heater
Greg Jackson
Wanted Heater
Post by Greg Jackson »
Need a heater mine is leaking , Greg Jackson
Re: Wanted Heater
Greg - The heater matrix is probably original - problem with a used one is that will be has old as your original one and could probably also start to leak at some stage - Clayton Classics do a replacement heater matrix core for it or can fully rebuild your existing heater - web link below
http://claytonclassics.co.uk/parts-upgr ... eplacement
Unfortunatlty they are not cheap
Re: Wanted Heater
I've copied this from the Javelin section. Maybe you didn't see it, or dismissed the thought.
'I've heard that 'K-seal' works on leaky radiators, so perhaps it might also work in the heater matrix, unless of course there's a joint that needs soldering'.
If it does work, you'll save a shed-load of money, so it may be worth a try.
