The easiest way to add items
The easiest way to add pictures to JowettGallery if you have Windows XP is to follow the instructions on the AddItem tab 'Windows XP'. This procedure will enable direct upload of multiple files from Windows Explorer with the click of the mouse. The following screen shots show how to do it once you have added the link in the Windows registry which is what you do when you follow the instructions.
g_id=1648,_ /help/Test,_ Forumadmin,_
AddItems-WindowsXP
AddItems-WindowsXP
From the JowettTalk webmaster.
AddItem-WindowsXP
The easiest way to add pictures to JowettGallery if you have Windows XP is to follow the instructions on the AddItem tab \'Windows XP\'. This procedure will enable direct upload of multiple files from Windows Explorer with the click of the mouse. The following screen shots show how to do it once you have added the link in the Windows registry which is what you do when you follow the instructions. A similar process is used for Vista and Windows7; but here the facility is added to the Print facility in the Photo Gallery.
g_id=1674,_ /help/Test/AddItem-WindowsXP.GIF,_ Forumadmin,_
AddItem-WindowsXP-2
AddItem-WindowsXP-2-2
AddItem-WindowsXP-3
AddItem-WindowsXP-4
AddItem-WindowsXP-5
