Using Gallery Remote to upload a set of pictures at once
g_id=382,_ /help/HowtouseGalleryremote,_ Keith Clements,_
GalleryRemote
GalleryRemote
From the JowettTalk webmaster.
Chose Gallery Remote from Add Items tabs. Follow the instructions to download and install the client onto your computer. This gets over restrictions on the Jowett.org server such as image manipulation facilities.Please follow the Gallery Remote Install instructions as this link no longer works.INSTALL INSTRUCTIONS HERE.
g_id=399,_ /help/HowtouseGalleryremote/AddItems.gif,_ Keith Clements,_
Run Gallery Remote
Run \'Gallery Remote\' from the programs on your desktop. Then add the URL to JowettGallery.Please note the URL after Single Sign On is now. https://jowett.net/gallery/
g_id=393,_ /help/HowtouseGalleryremote/AddURL.gif,_ Keith Clements,_
Log in to JowettGallery. Then select the folder you want by expanding each branch. You can fetch pictures already in the album you select.
g_id=402,_ /help/HowtouseGalleryremote/GalleryRemoteLogin_001.gif,_ Keith Clements,_
Having fetched the items you should be able to manipulate them. I have not prooved that works yet.
g_id=383,_ /help/HowtouseGalleryremote/FetchFromGallery-Rotate.gif,_ Keith Clements,_
What is really good is you can resize your photos. Setting the size to 800 is recommended.
g_id=390,_ /help/HowtouseGalleryremote/SetResize.gif,_ Keith Clements,_
You can use Microsoft Picture Manager to capture screen shots. Save screen shots as GIF or photos as JPG. Note that picture manager can also resize photos.
g_id=396,_ /help/HowtouseGalleryremote/MicrosoftOfficePictureManager.gif,_ Keith Clements,_
