Has any one any experience of fitting these? I'm unconvinced about the security of either the modified jubilee clip type fittings & that of the bent stainkess strip & self tapper design, both supplied by Hipwells.
Also, any issues with rebalancing the wheels?
Many thanks
Roger
As16 rimbellishers from Hipwell Arden
114
- Given Name: Roger
Re: As16 rimbellishers from Hipwell Arden
I do not think wheel balancing would be necessary. I have some fitted on the Javelin. Mine may not be the same fitting but no problems with security. If you are worried then tie wraps may solve the issue.
