SERVICING A JAVELIN / JUPITER
email Section Secretary
Drummond Black
Given Name: Drummond
Post by Drummond Black »
Technical Meeting on the Correct Servicing of a Javelin ( and Jupiter ). This meeting will take place on Sunday 3rd April 2016 at 19 Hartwood Road, Hartwood Shotts, starting at 1 pm. This should prove to be a very valuable session giving advice and an actual bumper to bumper service on a Jowett Javelin.
Some of the areas that will be covered will be as follows :-
ENGINE - Oil Filter replacement, Oil Change, Tappet Felts, Tappet Settings, Air Cleaner ( If still fitted ),
IGNITION SYSTEM - Replacing Spark Plug, Checking & Changing Distributor Points, Ignition Timing,
CLUTCH - Adjustment for correct play,
GEARBOX - Changing Gearbox Oil,
REAR AXLE - Changing Axle Oil, Checking correct Half Shaft play,
GREASING POINTS - Identification of all the Grease Nipples !!
BRAKES - Checking Brake Fluid Level, Adjusting Brake Shoes,
Plus many other points that should be checked during a Full Service.
Put the Date in your Diary SUNDAY 3rd APRIL 2016 at HARTWOOD
Drummond Black
Re: SERVICING A JAVELIN / JUPITER
Wow !! Calls and comments coming in and another area will be added,
Preparation for your Service !! Correct Tools, Spares and materials required.
These will all be covered.
Return to “Scottish”
