We are currently building a javelin up from a painted body and many boxes of parts. Sadly we didn't take to bits, the shell has been restored by another company and is missing brackets and various parts, no reference pictures where taken of the initial strip down. I'm after pictures of the battery box, as it doesn't currently have one and I want to fabricate something similar to what they originally had, it also has none of the mounts for the spare wheel holder.
If I could also have pictures of where the brake pipes route on the front that would help me massively, along with battery cable routing, general component locations, and various shots of engine and underbody, I have searched though posts of restorations on here already which have been a wealth of information.
Many thanks in advance.
pictures of the underneath
Tonybarnard
- Your interest in the forum: We are currently doing a full restoration of a javelin, the car is just a painted shell, we didn't strip it so every resource we can find is proving very handy.
Re: pictures of the underneath
TOPIC There should be one here
Pictures
TOPIC Has some detail of corrosion to be replaced.
Note that the later Javelin has a different arrangement which is open with a support at the base and a clamp with long threaded rods.
I will try to uncover the shell in the garage and take pictures.
Pictures
Hi Tony,
See my previous post as Forumadmin. There are other pictures but some of these are only available to club members as they are part of the club archive or in personal folders.
Tonybarnard
Hello Keith
Thank you for those, they will prove very handy.
The car in question is of a later design with an open holder secured on the front edge with a hinge of some description on the body that allows it to drop down when the screw on the rearward edge is undone.
Alf Heseltine
- Given Name: Alf
Hi Tony, here is some of the brake pipe layout.
Regards Alf
Regards Alf
