Windscreen Dimensions
During an interesting afternoon looking at the Coachcraft Jupiter, the rebuilders wanted to know if a Javelin screen would fit. So I gave them these dimensions today.
Width at centre point measured around outside=1125mm.
There is a taper so bottom is 5mm wider and top is 5mm narrower.
Height at centre point=394mm
There is a taper towards centre so the screen is higher by 4mm before it starts its radius at the corner.
Curvature (height bottom edge of middle of screen from floor when screen laid outside up)=90mm.
Radius of top curves=75mm
Radius of bottom curves=40mm
