Does any one know the weight of a Javelin and how it compares with a Jupiter?
I weighed my Jupiter on my single axle trailer and both together was 1240 kg.
Cheers.
Weight of a Javelin
dougie
- Your interest in the forum: Long time Jowett owner with a Javelin, Jupiter and Bradford.
- Given Name: Doug
Weight of a Javelin
Cranky Wife,No Cupholders.
Jupiter,Javelin, Bradford.
Robin Fairservice
- Given Name: ROBIN
Re: Weight of a Javelin
According to my Javelin Instruction Book, the Javelin shipping weight is 2200 lb, and the Kerb weight is 2290 lb.
Andrew Henshall
According to the Jupiter Instruction Book, the Dry weight of a Mk1 Jupiter is 812 kg, which seems very light.
The Autocar in March 1950 reported the "weight" of a Jupiter to be 1510 lb approx (685 kg)! This was based on JCS publicity material. Then in December 1950 the Autocar Road Test reported the Jupiter had a weight of 2107 lb (956 kg).
The 1951 Javelin had a Dry weight of 2168 lb (983 kg), and a Kerb weight (unladen) of 2258 lb (1024 kg)
Cheers,
Andrew
Cheers,
Andrew
Andrew Henshall
Member: JCC, JOAC & JCCA
Robin Fairservice
- Given Name: ROBIN
If we start to take nunbers from Road Test here are some:
JAVELIN
Motor, 1949: Unladen road weight: 2296 lb; Laden weight: 2744 lb
Motor, 1952: Unladen kerb weight: 2408 lb (de Luxe)
Motor 1953: Unladen kerb weight: 2408 lb de Luxe)
JAVELIN JUPITER
Autocar (no date): 2107 lb
Autocar (no date) (Jupiter Mark 1A): Unladen 2121 lb; Laden 2535 lb
JAVELIN
JAVELIN JUPITER
When racing in the 90s I did check the corner weights of my Jup, but cannot find the notes.
I will ask Richard if he knows what he has got his Jup's weight down to.
We now have a Javelin shell approaching completion with the lead replaced and a shell with all the lead stripped out of it. Also a Jup bare chassis. All I need is as big enough set of scales.
All the mechanical sub assemblies of the Jav are waiting to go in, so they could also be weighed.
