Recovering passwords and single sign-on
This post will hopefully help us move towards single sign-on. You all need to check that the email addresses in JowettTalk and JowettGallery are the same in each of your accounts as they will be used for matching up the two accounts. It would help if these two addresses are also the same as in the latest membership list from your club as on-going Gallery access will be enabled by reference to these.
Note that usernames in JT and JG could be different for the same user and thus this is the only way of matching accounts for single-sign on.
Note that passwords will also have to be upgraded to be greater than 11 characters with a mixture of upper and lower case and also be made the same on both systems.
You will find in TOPIC the Gallery a series of screen shotsthat take you through the steps to make your credentials on JowettTalk and JowettGallery the same. Please read the description at the top to guide you through each step. The process also shows you how to recover your passwords should you have forgotten them. Thus I will post this also in the section that is accessible to the public and make the JowettGallery help album public.
If you have any issues with any of these changes or have a problem with meeting the goal then please contact me.
