Plans for wood
Plans for wood
Hi Keith,
Glad you had a good time in NZ.
I have attached the plans . I had assumed the door pillars were 90 degrees off the timber that lies on top of the chassis but after I built my frame I had to cut the top wood behind the door pillars and lean the pillar back 15mm off vertical. This allowed the bonnet to fit properly.
Good luck with Jack's build. Keen to see photo's of his progress.
Best....
Gaven Armit
braddiewood.pdf
See this post for pictures
