WTB: Jupiter wing budget locks 55609/55610
Hello All:
Looking for a set of the little cam locks which fit inside the wings and grasp the catch at the bottom of the scuttle. Might anyone have a set not in use?
Cheers,
Scott
Re: WTB: Jupiter wing budget locks 55609/55610
Hi Scott,
I had a quick look, but could not locate any. I have a faint recollection that somewhere there may be a couple , but that recollection also recalls they are rusty. I will keep your request in mind whenever I rumage in the cellar.
Thanks Keith> Need them for Craig Hall's car. I might have to make a set if nothing turns up in the next 6 weeks or so!
Cheers.
Andrew Henshall
Given Name: Andrew
Post by Andrew Henshall »
I think you mean the hooked budget locks that are currently available commercially.
See:
http://uesint.com/shop/hooked-budget-lock-lh-316200/
http://www.ironmongerydirect.co.uk/prod ... lock_brass
http://www.nichelocks.com/Budget-Locks
Andrew
Andrew Henshall
Member: JCC, JOAC & JCCA
