Bottom Near-side Rear Door Hinge
Robert Dudley
Post by Robert Dudley »
I missed the parts slot again last night. You would think I could remember to phone at some point between 7 and 9 would you not?
I have a broken bottom rear near-side hinge and need a replacement. They may be interchangeable left and right and the front part may be the same as the rear shape but turned upside down. Or may be not. Does anyone have any ideas? I will try to weld the old one if all else fails. I have searched google for ages with no sign of anything vaguely matching the double set up.
Thanks in anticipation
Re: Bottom Near-side Rear Door Hinge
Robert.
I should be able to find one. I will look tomorrow. I also forgot to phone them last night.
Robert Dudley
I called into Martin Benning today and he says Peter at Evesham may have one so I was going to get the old one from the bloke doing the welding and take it over.
If you can find one it will save me a journey.
Many thanks for your help.
As per voicemail, I have a brand spanking new one. Please call me if you want it posted.
