David had sent me a blank piece of ally, so I marked this out putting the centre of the holes not where you might first expect. I chose a drill 3 mm smaller than the O rings so that the eventual shape of the holes could maximize the very small amount of land between some of the holes and other holes or the outside world.
This was the plate I took out that used smaller O rings.
and this is the newly fabricated one
this with the O rings installed
This shows the spin off filter mod
Crack testing around the pressure gauge take off.
After cleaning the unit in the parts washer and drying it with the air gun , the housing was sprayed with special cleaner, dried, then a UV penetrator and left for 15 minutes and then sprayed with special disclosure spray. I now need to wait until there is some UV from the sun to see if there are any cracks. Unfortunately the UV lamp I used with my disco lights in the late 60's has long since expired.
